Results 1 to 10 of 10
    2013 Superlight 650B conversion question. 100mm or 120mm Front fork?
    Hello,
    Just a quick question. I am about to purchase the 2013 SC Superlight frame and convert it to 650B. I have a chance to get a deal on a 120mm fork, but wondering if this is too much travel? Should I just stick with 100mm? Thanks.
    NedwannaB
    Reputation: JMac47's Avatar
    Quote Originally Posted by RSMBiker View Post
    Hello,
    Which fork? If FOX you can split difference and go 110. That's what I did/doing with my build.
    Wait,who did he tell you that?....
    Hello,
    X-Fusion Velvet RL 120mm
    Reputation: reformed roadie's Avatar
    Get the Velvet, try it at 120, if it is too high, adjust to 100. It has a push-pin on the air-spring rod...fairly easy change.
    NedwannaB
    Can they be travel reduced? Simple procedure.
    I realize your question was more on handling with different travel. I was up against same thinking as I have 2 different forks i could use. Went with the one already set at 110mm since this bike will be replacing a 140mm trail bike. Trying to keep the bb height increase with the bigger wheels to a minimum.
    NedwannaB
    Bingo!! We have a winner!
    Quote Originally Posted by JMac47 View Post
    No to sure if I can do it. But I hear I can send it to Xfusion for a cost to lower ($40). If I have to send it in, then the deal does not seem too great. When looking at forks to buy, I just don't want to waste time on a 120mm fork if it will ruin the proper geometry, BB ht, etc. Maybe I should look at an adjustable Fox fork
    Reputation: madsedan's Avatar
    Aug 2010
    Agreed, and the velvet is a great fork, I ran one on my 650b nickel.
    Hardrock 29er, Niner EMD9, Cannondale F29, Camber Expert, 650b Nickel all gone.
    2014 Giant Anthem 27.5 here.
    NedwannaB
    No to sure if I can do it. But I hear I can send it to Xfusion for a cost to lower ($40). If I have to send it in, then the deal does not seem too great. When looking at forks to buy, I just don'twant to waste time on a 120mm fork if it will ruin the proper geometry, BB ht, etc. Maybe I should look at an adjustable Fox fork
    Well putting "proper" geometry aside, since we're playing around with different wheel size and all, the V3 SLs are designed 100/120. Keep in mind though if your first conversion jacking up the bb is going to take away some of the carving capabilities but gain some added ground clearence which is a tradeoff.
    Thanks Everyone!
  1. New Superlight 650b conversion!
    By tommyrod74 in forum 27.5 - 650b
    Last Post: 04-19-2014, 04:37 AM
  2. Manitou R7 PRO 120mm to 100mm conversion?
    By Palych in forum Shocks and Suspension
    Last Post: 08-26-2012, 04:08 AM
  3. Replies: 2
    Last Post: 04-04-2012, 12:49 PM
  4. 100mm Fox F RLC conversion to 120mm
    By Phalophalot in forum Shocks and Suspension
    Last Post: 05-12-2011, 11:20 PM
  5. Replies: 6
    Last Post: 05-07-2011, 06:01 PM
