Results 1 to 8 of 8
    Oct 2012
    2013 Fox 32 FLOAT 140 CTD O/C Axle to Arch?
    Hi, I'm having a hard time finding the measurement for the axle to arch for the 2013 Fox 32 FLOAT 140 CTD O/C. Only thing I can find is the A2C of 510.9 mm
    If I get it I would be looking to fit Neo-Moto 2.3 = 352mm
    Darius
    Nov 2007
    I dont know the answer for the 2013 32 float 140ctd, but the 2013 34 float 160 ctd if bottomed out the crown will hit the tire. I had a 2.35 nevagal
    Oct 2012
    Do you know the measurement from center of axle to bottom of arch?
    May 2005
    Unless they've changed the lowers (which I doubt) it will clear the Neo-Moto 2.3" easily at the arch. In fact it clears probably the tallest 650B tire (Schwalbe NN 2.35") by about 3mm. That tire will hit the bottom of the crown but the Neo Moto should be fine (just barley grazes my 140 Float if slammed down hard with no air)
    2013 Banshee Spitfire V2 650b
    Nov 2007
    Quote Originally Posted by dariusf View Post
    I just measured it. It appears to be 14 inches.
    Oct 2012
    thanks for the info, appreciate it
    Quote Originally Posted by mudfoot124 View Post
    Shouldn't this be in mm's?
    Oct 2012
    well, one can measure in whatever units one likes, the distance will still be the same
  1. Replies: 0
    Last Post: 03-09-2013, 08:43 AM
  2. Replies: 0
    Last Post: 08-19-2012, 08:38 PM
  3. 32 Float 150 Vs 34 Float 160 - axle to crown
    By kakrafoon in forum Shocks and Suspension
    Last Post: 06-06-2012, 03:36 AM
  4. Replies: 2
    Last Post: 06-13-2011, 08:16 AM
  5. Axle to crown of 36 float vs 32 float 150
    By swade in forum Shocks and Suspension
    Last Post: 06-12-2011, 11:39 AM
