Results 1 to 16 of 16
    Reputation: dynamic161's Avatar
    Jan 2011
    2011 Scott Spark RC Carbon Build
    What fork should I go with? I will be building this into a 100mm xc race rig and would like to use Racing Ralphs.
    X Fusion Velvet RL2 26/27.5 Specific
    Cannondale Lefty (not sure exactly what I would need to make a Lefty work on a standard 1-1/8" headtube)
    Older Fox Float 32mm Stantions (not sure what model / years will work)
    From what I understand none of the Rockshox forks will work, am I right or wrong here?
    Weight is a priority for the build
    Any insight would be much appreciated. Just jumping into the 27.5 scene.
    '12 Anthem X29 Custom Build
    '11 Masi Evolution Custom Build
    just some guy
    Reputation: talabardio's Avatar
    A 650b wheel definitely fits into the back?
    Sep 2012
    any for the fox forks seem to work - I run the new Fox Fit love it.
    any for the fox forks seem to work - I run the new Fox Fit love it. - there are also some Manitou R Sevens that will work as well.
    just some guy
    Quote Originally Posted by dynamic161 View Post
    These guys have some stuff to help with Lefty forks.
    PROJECT 321 | Products: Bicycle
    I thought that it was established that Scott Sparks don't fit 650b, so I am very intrigued by this thread.
    Jan 2011
    Quote Originally Posted by talabardio View Post
    Thanks. I have done some digging and found a picture of a 2011 Spark RC with 650b front and back. I won't be 100% positive until I test fit the wheels and tires but I will keep you updated.
    jju
    jju is offline
    how about the DT swiss front fork? I want to do the same project on 2010 spark RC
    Could you make more pictures about the space between rear wheel and triangle?
    just some guy
    Testing the rear at compression is what looks like will be the tricky part. The tire might run into the seat tube.
    jju
    jju is offline
    I am planning to put 650b wheels on scott rc 2010. I will send the rear shock to a service, do i ask to do bushing for that shock or not?
    Thanks,
    I think I have read quite a few posts that 650b is OK for the rear on older Sparks like on the photos above. I was planning to convert my 2008 Spark 10 too, but just couldn't find a light-enough fork to keep the weight and geometry close to my 26" build to give it a go. Any neew ideas would be great!
    jju
    jju is offline
    I am planning to put new fox fork 26" with ctd, but have no ideas how to do twin lock to work with fox fork instead of dt swiss?
    Jan 2011
    Well, it took a little work to make the Racing Ralph 2.25 650b tire fit. I ended up fabricating bottom out shims and installed them in the shock. The shim stack height is 6.5mm made out of plastic washers that were trimmed to size to fit the shock shaft/housing. Without the shims the tire just kissed the seat tube at full compression with 25 lbs in the tire. With the shims in the shock I have about 10-15 mm clearance at full compression.
    Chain stay clearance is a little tight with the Ralph, probably 2.5 to 3mm.
    What do you think?
    Jan 2011
    Here's a pic of the bike. Running Stans Crest wheels.
    I will also be using a 2010 Fox Float RLC Fit in the front.
    Could you include some pictures of the fork, I will like to see the clearance on the arch and on the crown with the fork deflated.
    thanks
    Jose
    Reputation: craigstr's Avatar
    Sep 2003
    Love the bikestand in the living room. Nice!
    NedwannaB
    Reputation: JMac47's Avatar
    I kinda like the living room itself!
    Wait,who did he tell you that?....
    Jan 2013
    nice!
