FAT BIKES
WINTER APPAREL
TRAINERS
Page 1 of 11 1 2 3 4 5 ... LastLast
Results 1 to 25 of 272
    Reputation: bikeny's Avatar
    Introducing the Carver Gnarvester!
    What do you get when you cross a Carver 420 Ti and a Surly Krampus? The new Carver Gnarvester! It's basically a 420 with room for Knard 29+ tires. I have not ridden it yet, still building it up, but first ride will be in a couple of days.
    My story if you're interested, if not, skip to the pictures. When I heard that Surly was releasing 29x3 tires, I knew I wanted to try them out. I managed to squeeze them into a frame I already had (thread here: Ti Carver + Knard = ???). After a couple of rides, I knew I wanted a dedicated frame to run the Knards, but with some geometry tweaks and lighter than a Krampus. So I sent Davis at Carver an email asking about doing a custom 420 Ti with room for Knards. He sent a quick response that read 'like this?' with a couple of pictures of exactly what I requested. Apparently, he had already thought of it and was testing one. After a couple more email about details, turns out he had another frame for sale, in my size no less, which was quickly on it's way to me, along with a new design tapered carbon fork.
    First teaser pics below:
    Attached Thumbnails Attached Thumbnails Introducing the Carver Gnarvester!-gnarvester-1.jpg
    MTB B'dos
    Reputation: LyNx's Avatar
    Destiny, nothing else Look forward to the reports.
    MTB Barbados
    My Phantom pics
    Must resist using all caps and bold to convey my jealousy.
    Reputation: Jstews's Avatar
    Oct 2011
    Wowza. Looks great, can't wait to see it built up..
    I'll bet Davis at Carver will be getting a few more emails.
    This is incredibly exciting.
    Reputation: MMcG's Avatar
    Jul 2003
    Davis Carver Rocks. Seriously - he's a super cool guy.
    WNC Native
    Reputation: nitrousjunky's Avatar
    Some smart thinking on Carver's part to get on the ball with this. Will be watching to see it complete and hear your thoughts!
    "I ride to clear my head, my head is clearer when I'm riding SS. Therefore, I choose to ride SS."~ Fullrange Drew
    Quote Originally Posted by nitrousjunky View Post
    Agreed! I will be updating, so keep an eye out. Couple more pictures:
    Attached Thumbnails Attached Thumbnails Introducing the Carver Gnarvester!-gnarvester-5.jpg
    Geo charts?
    MTB B'dos
    BikeNY, are the angles the same as the 420 then? I saw your post and got real tempted, went to their site as a Ti HT is in my future, but was a bit disappointed with the 69* HTA with a 140mm fork, now if it was 69* with a 120mm fork I could do with that. Right now my front runner for my future Ti HT frame is the Titus Fireline EVO, although having room for a Knard is something that could sway me to the Carver, despite the un-believeable price Titus is selling the FL EVO for.
    MTB Barbados
    My Phantom pics
    Yes, geometry is basically the same as the 420 with longer chainstays and room for the Knard. According to the Carver site the HT angle is 68 with a 140 fork, 69 with a 120 fork. The fork I got has an AC of 490mm, so that should put the angle at around 69.5. I hope that helps!
    Reputation: SlowPokePete's Avatar
    Mar 2006
    Can't wait to see it ... I'm sure it will be sweet.
    But I thought when it came to carbon, you had a "just say no" policy ...
    SPP
    Rigid.
    Quote Originally Posted by SlowPokePete View Post
    SPP
    You got me! Up until now that is absolutely correct. Even my road bike doesn't have any carbon on it! I figure carbon has come far enough that I can give it a try.
    I would buy that if it was also belt drive compatible or available as an option. I'm thinking 29+ belt drive Rohloff.
    First ride report
    So I finally got my first ride in on the Gnarvester, so just a quick report here. I had a few component compatibility issues to sort through which took a bit longer than I wanted, but all good now.
    First of all: I know I have a ton of spacers under/over the stem, so don't comment on it! I am still fine tuning the fit and did not want to cut the steerer too short.
    The ride was about 1.5 hours with a couple of stops to make adjustments. One word description: FUN! Took a little bit to get used to the different handling compared to the other frame, mostly the slacker headtube angle. The bike felt very solid: The shorter stays give it that playful feel and make it easy to get the front wheel up or bunnyhop. slack HT angle make it plenty stable when the speed picks up, and I had no problem keeping the front end down, even on steep techy climbs. Lastly, I am still amazed at the climbing ability of the Knards! If you have the legs for it, it just rolls right up the steepest rocky, rooty trails without a hiccup. You almost don't have to worry about your line and just pedal!
    I have the sliders set all the way forward, which gives a CS length of 17.5", and there was still plenty of tire clearance. This thing is ready if/when Surly comes out with a knobbier 29+ tire. Weight on my crappy scale was about 26.5lbs, about 2 pounds lighter than my other setup. The majority of that savings was thmoving from a steel Niner fork to the Carbon Carver fork.
    Questions? ask away!
    Attached Thumbnails Attached Thumbnails Introducing the Carver Gnarvester!-gnarvester-7.jpg
    Reputation: rob1035's Avatar
    that's really cool! Now ditch those silly pulleys and cables and really enjoy it!
    Forgot to include this in the last post, here is the parts list:
    Carver Gnarvester frame, 18"
    Carver Carbon tapered fork, 490mm A-C, 45mm offset
    Cane creek 40 tapered headset
    Wheels: Jeff Jones 50mm (actually 48mm) 29er rims, Hope 100mm front & 135mm singlespeed rear hubs, DT Comp butted spokes, 120tpi Knards, built by Mike C. He claims they are *really* Burly!
    6 speed custom Ti cassette, 12-33: 5 cogs from an old Boone 2 speed cassette and an offset 33t Ritchey to cog
    Truvativ AKA GXP cranks (same as SRAM X9) with 28t Ti HBC spiderless chainring
    Shimano XTR M960 rear derailleur
    Shimano 8 speed barend shifter mounted on a Paul Thumbies mount
    SRAM PC68 chain
    Old style Time ATAC Titan pedals (the best pedals ever!)
    Old style Moots layback titanium seatpost
    WTB Silverado titanium railed saddle
    Race Face stem (temporary)
    Groovy Luv Handle titanium bar
    Old Hope Mono Mini brakes, 180/160
    Ergon GS2 grips (soon to be GS1 without barends)
    King Cage
    Salsa seatpost clamp w/ 27.2 to 31.6 shim
    I think that's it.
    I also plan to have it setup for easy singlespeed conversion. I will have a second chain that is the proper length, and then set the sliders at the appropriate spot for my gearing. The swap will then require only:
    1. Remove chain
    2. Unscrew derailleur bolt
    3. Unscrew shifter bolt (mount is hinged, so shifter comes off without removing brakes/grips)
    4. Remove 3 clips holding shifter cable
    5. Swap cassette for SS cog and spacers
    6. install second chain
    Jul 2003
    Mighty nice bike sir!
    WNC Native
    Nice build, bet that thing is a blast.
    MTB B'dos
    So, so itching for something like this, can't wait until my Blunt35s arrive and I can give a Knard F/WW LT R a go on them on my Monkey
    MTB Barbados
    My Phantom pics
    Reputation: jncarpenter's Avatar
    Looks sublime!
    I was ready to put a deposit down on a custom frame to accommodate Fat/29/Knards...now it looks like I may be selling at least one bike in anticipation of an upcoming relocation.
    Some day soon tho...
    Quote Originally Posted by bikeny View Post
    1. Remove chain
    Very cool!
    Professional Crastinator
    Reputation: Fleas's Avatar
    THAT is something I can get excited about!
    Good plan.
    -F
    It's never easier - you just go faster.
    Reputation: 4nbstd's Avatar
    1. Remove chain
    Ghisallo Wheels
    I'm really good looking.
    You have the coolest bike around! I plan to have something similar soon. So it sounds like the CS length will be within a few mm of the Krampus, tough job fitting all that stuff in a tight spot. What is the BB drop, or BB height? Also how stiff does the rear end feel? The Krampus felt very soft the me in the rear.
  1. Introducing the Bandit
    By Transition Bikes in forum Transition Bikes
    Last Post: 08-06-2015, 11:24 PM
  2. Introducing the best XC trail dog!
    By pmarshall in forum California - Norcal
    Last Post: 11-12-2012, 09:48 PM
  3. Introducing the wife
    By Sebas69 in forum All Mountain
    Last Post: 04-28-2012, 09:06 PM
  4. Introducing myself...
    By prowler220x in forum Beginner's Corner
    Last Post: 06-02-2011, 02:39 PM
  5. Presentandome, Introducing myself
    By betovallejo in forum Mexico
    Last Post: 02-15-2011, 01:13 PM
Follow MTBR on Facebook
