Results 1 to 11 of 11
Thread: Tubeless
    Sep 2018
    Tubeless
    So I wanna run tubeless 26x2.3 in the front and tubed 26x2.2 in the back.Is this a good idea ?
    IMO, no - I get a lot more pinch flats in the back, so where's the benefit?
    Sealant is a hassle, why mess with it for only one tire?
    Reputation: J.B. Weld's Avatar
    Quote Originally Posted by phantoj View Post
    So is replacing punctured tubes.
    I agree though, do both or do neither.
    I brake for stinkbugs
    Sep 2018
    I want to do both in future,but for now I want to do the front because I never get a flat in the back.Thanks for the advice though
    Reputation: MSU Alum's Avatar
    Then do it.
    Why would it be a bad idea?
    mbtr member
    Reputation: scottzg's Avatar
    Quote Originally Posted by TheHealer View Post
    That's unusual.
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
    I went tubeless 6 years ago. Haven't had a flat in 6 years. Better traction, less rotating weight, more supple ride...no negatives.
    Reputation: Cuyuna's Avatar
    May 2017
    Neither good nor bad. Thereís no reason not to do it that way. There will be those here, however, that will be upset that youíre not doing it the way that they think you should do it. Iím kind of surprised that no has criticized you for your tire size choice. Yet.
    Itís just a hobby, right? No right or wrong, just conventional vs unconventional.
    I agree, this is unusual. Are the tube pinch flatted or punctured? And if punctured, on the outside or rim side of the tube? Check your front rim and tire for debris or burs inside the rim. Consider using rim tape if you don't have it.
    the half breed devil
    Reputation: shekky's Avatar
    Oct 2011
    Quote Originally Posted by briank View Post
    with all due respect, what sort of drugs or temporary insanity would drive a person to use tubes and no rim tape?
    Jan 2016
    I do, but only because I cannot get one of my rims and tire to properly inflate and hold air despite numerous attempts. So until that tire gets worn out, it'll use a tube.
  1. Replies: 4
    Last Post: 05-30-2015, 10:03 PM
  2. Using tubeless tire on a non-tubeless wheel
    By Will Goes Boing in forum General Discussion
    Last Post: 05-07-2012, 04:58 PM
  3. re-sealing tubeless tires--first time w/ tubeless!
    By gsmolin in forum Wheels and Tires
    Last Post: 10-22-2011, 11:23 AM
  4. Replies: 5
    Last Post: 02-15-2011, 12:30 PM
  5. Best am tire to run tubeless, also tubes Vs. Tubeless
    By FRidekid in forum Wheels and Tires
    Last Post: 01-25-2011, 04:07 PM
Members who have read this thread: 83
