Results 1 to 11 of 11
    Feb 2018
    New question here. Right inner tube
    Hi, i'm a newbie in biking. i just want to know if i can use a 26' x 1.75-2.5 inner tube to my 26 x 2.7 tires?
    Any inputs will be greatly appreciated.
    Reputation: armii's Avatar
    Jan 2016
    tubes are pretty flexible. You can actually stuff a 27.5 tube in a 26 or stretch it to a 29 and have it work in a pinch.
    See what I did there, flexible, pinch.
    Feb 2018
    New question here. Right tube
    Quote Originally Posted by armii View Post
    Thanks for the info
    Class Clown
    Reputation: dundundata's Avatar
    I find with tubes yes you can use different sizes but if you can get tubes with a smaller range they are better. For instance the tubes you have would probably be rather large for anything under 2.0. Workable but not ideal. The tubes I buy (qtubes) have less range, for instance:
    1.9-2.125
    2.1-2.3
    2.4-2.7
    I've bought Specialized tubes that have a range of 1.75-2.4 I believe and they are the same size as qtubes 2.1-2.3.
    Feb 2018
    Wink Right tube
    Quote Originally Posted by dundundata View Post
    1.9-2.125
    2.1-2.3
    2.4-2.7
    thanks for another insightful info. im beginning to enjoy the group!
    Reputation: MSU Alum's Avatar
    Quote Originally Posted by ricky1081 View Post
    That'll pass!
    Reputation: MOJO K's Avatar
    You'll want it to match what you're using for the Left inner tube.
    Jan 2018
    Should be no problem running that with your 2.7 tire.
    Jan 2016
    Quote Originally Posted by MOJO K View Post
    Wouldn't that be the leftout-er tube?
    Oct 2016
    1.9-2.125
    2.1-2.3
    2.4-2.7
    This times a bunch. Tubes by nature will stretch quite a bit. When in doubt, go smaller.
    Tried to tell my GF that but..........
    DAMN THE MUD, FULL SPEED AHEAD!!
    Apr 2018
    That's no problem at all, inner tubes are flexible to use.
    most inner tubes have a wide range :
    54-559 26x2.10
    55-559 26x2.15
    57-559 26x2.25
    60-559 26x2.35
    62-559 26x2.50
    64-559 26x2.50
    65-559 26x2.60
    70-559 26x2.75
    75-559 26x3.00
    You can use for example
    https://www.fietsweb.nl/nl/schwalbe-...-ventiel-60-mm
  1. Seat tube, top tube, head tube deal
    By calstar in forum Frame Building
    Last Post: 08-29-2013, 10:12 AM
  2. Tubeless sealant in actual inner tube?
    By Mulcher in forum Wheels and Tires
    Last Post: 08-08-2011, 04:52 PM
  3. Can I use this w/ inner tube?
    By Tjay in forum Wheels and Tires
    Last Post: 02-14-2011, 01:45 PM
  4. Super Inner Tube = No more more Flat Tires
    By johnnycrash in forum Wheels and Tires
    Last Post: 01-30-2011, 05:51 PM
  5. How to Patch an Inner Tube
    By shiggy in forum Wheels and Tires
    Last Post: 01-10-2011, 12:14 PM
