Results 1 to 8 of 8
    Mar 2016
    New question here. Chainline problem with 1x10
    Hi everyone,
    I'm having some kind of problem with my recently converted bike to 1x10, as the chainline is way off where it should be.
    I double checked that the bottom bracket spacer is well placed (2.5mm in the drive side for 73mm BB) and the chainring is attached correctly to the middle position in the old triple crankset i have (SLX M-670/675)
    I'm using a wide range 10speed 11-42 sunrace cassette and i'm getting the optimal chainline in the 7th cog, if i'm not wrong thats 2 cogs offset from optimal.
    It seems like i need 8-10mm chainring spacers....?? o.O
    Any ideas please
    Thx in advance
    Kind regards
    Jan 2009
    What's your chainline first?
    https://www.sheldonbrown.com/chainline.html
    Mar 2016
    Quote Originally Posted by thesmokingman View Post
    I measured and from center of seat tube to center of chain above chainring is 50-51mm
    Hub is 135x10
    Jan 2009
    Refer to this post below for starters. I think switching to a N/W ring will get you to 47mm right off the bat which is close to ideal.
    Optimal 1x10 chainline
    Mar 2016
    Thank you. I've already have a NW chainring installed
    Any ideas where can i find stuff like this please? (BIG bolts and nuts and spacers)
    http://3.bp.blogspot.com/-523w5nTsWe...0/IMAG1668.jpg
    Jan 2009
    spacers
    https://smile.amazon.com/Wheels-Manu...dp/B001CJZ9T0/
    tabs
    https://smile.amazon.com/Race-Face-C...dp/B00B5Y1YB4/
    For bolts, your stock ones should mwork otherwise there's a bazillion to choose from.
    Mar 2016
    spacers
    tabs
    Sorry but, arent those tabs to install at the outside of the crank's sipder instead of inside where i need them to move the chainring inwards?
    Jan 2009
    Yea, the tabs are for the outside and protect the arm junction. They also look cool.
  1. Optimal 1x10 chainline
    By BmoreKen in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-09-2015, 10:49 AM
  2. SRAM 1000 + BB92 1x10 Chainline Problems
    By warimono in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-09-2014, 12:02 PM
  3. Process 153 1x10 chainline problems
    By warimono in forum Kona
    Last Post: 05-28-2014, 12:08 PM
  4. Slayer 30/50/70 Chainline/Running 1x10
    By shredjekyll in forum Rocky Mountain
    Last Post: 11-05-2013, 10:41 PM
  5. Best chainline for 1x10
    By s-keeper in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-23-2011, 12:28 PM
Members who have read this thread: 47
