Results 1 to 5 of 5
    Feb 2018
    26 build help for an MTB newbie
    Roadie here looking to get into MTB.
    I was given a full 26 bike with good components, wheels, shocks, etc but the carbon frame is cracked. I have found locally a guy selling a Yeti 575 (2013) frame that I am thinking of buying and building up with the components I have. My concern is with the shock I have and whether its compatible with the frame. Its a Fox RL from 08 or 09, not sure. The fork does not look "tapered" so unsure if it will fit with the frame. So I guess the question is whether I can use a non tapered fork with this type of frame or do I need to use another fork or get a different frame?
    thanks for the guidance.
    May 2016
    If the fork you have is tapered it will fit right in, if it is a straight tube steerer it will still fit with the proper headset. Several companies, most notably Cane Creek make headsets fo straight tube steerers into tapered headtube bikes. You just want to make sure your current steerer tube is long enough to fit through the Yeti's headtube. What type of carbon frame do you currently have?
    Feb 2018
    Thanks! the current fork is straight so I guess I need to find a new headset.
    The current frame is a Tomac Carbide.
    Reputation: Mr Pig's Avatar
    There will be bits and pieces you'll need to change but most of your stuff should fit. The fork will fit with the correct headset and adapter.
    Shocks vary in stroke length, overall length and usually in their settings too. You'll need to check the spec of the shock for both frames. Worse case, you eBay your shock and buy another one.
    But you will make this work.
    Quote Originally Posted by FatGuyDempsey View Post
    It depends on the headset. Many include an adapter (plastic ring!) that lets you use them with both tapered and straight forks.
  1. Newbie Build Help!
    By TheNamesPool in forum Yeti
    Last Post: 07-30-2017, 09:34 AM
  2. Hotrock 24" - Newbie Build but totally bamboozled....can anyone help?
    By Alan J IRL in forum Families and Riding with Kids
    Last Post: 11-01-2016, 09:36 AM
  3. Newbie, please help me build my scalpel.
    By BocaScalpel in forum Bike and Frame discussion
    Last Post: 05-23-2013, 06:04 PM
  4. niner build help newbie to build world
    By desflurane in forum Niner Bikes
    Last Post: 12-18-2011, 04:19 PM
  5. need help with bike build..i am a newbie!
    By jrs67 in forum Cyclocross
    Last Post: 11-01-2011, 07:36 AM
