Results 1 to 6 of 6
    Nov 2008
    006 RS Tora Dust Seal Issue
    So...I decided to service the Tora but it turns out that I don't have the standard dust seals / foam rings.
    I can't find much info concerning whether I can replace the current seals with the standard dust seals / foam rings or where I can find the appropriate seals.
    Any help would be appreciated...
    I'll update with pics soon.
    Nov 2008
    Also, while trying to pull the seals out (which are much harder than the standard seals) I accidentally pulled off one of the internal retaining spring rings.
    Nov 2008
    Ok, here are the images of my current seals and the retaining spring that popped out while I was trying to remove them.
    Here is a link to a forum post where it seems someone is dealing with the same thing: https://singletrackworld.com/forum/t...are-the-foams/
    I'm going to keep researching but if anyone could chime in it would be super appreciated.
    Nov 2008
    Well, I was able to get the spring retainer back in but I've notices that there is a small tear in the seal now. I tried very carefully to pry the seals out but there doesn't seem to be a way to do it with conventional tools without damaging the seals further.
    Would be awesome if anyone could chime in with some info.
    Dec 2013
    Kind of hard to tell from your photos, but could you possibly have the seals that are 2 rubber seals per leg with a thinner wiper on them? I had a reba once that had that setup, and they were harder to remove for sure.
    If that is the case, what I did with that particular reba was just to swap in a "normal" seal kit with a deeper dust wiper and thicker foam ring and it worked fine.
    For removal, if you have a DH tire lever, or a nice chunky plastic tire lever, I would suggest that with firm force prying up and slowly work your way around. If those seals have been in there for a while, they are pretty snug and will need some patience/gentle-yet-brute-force
    Deflated Cyclestuff-
    random junk/old collection of new-old-refurbished parts/bikes for sale on eBay
    FATTrailer for the kiddo
    Nov 2008
    Thank you SO much for the reply!
    When you say "deeper dust wiper and thicker foam ring" do you mean aside from the standard ones that everyone sells? I have a set of grey dust seals with the foam rings that I'm hoping will work but if I need to get deeper ones I will, just not sure where to find them.
    Thank you again for the help!
  1. '09 Shox Tora SL or '10 Tora 318?
    By myersv in forum Shocks and Suspension
    Last Post: 09-04-2013, 06:53 PM
  2. Rockshox Tora what upgrades are there
    By wolfboy0000 in forum Shocks and Suspension
    Last Post: 05-06-2013, 06:57 AM
  3. Rock Shox Tora 289 vs Tora 302 U turn
    By XDEEDUBBX in forum Shocks and Suspension
    Last Post: 05-15-2011, 09:56 PM
  4. Rockshox Tora TK 29 SL vs. Recon Silver SL 29
    By bwalton in forum Shocks and Suspension
    Last Post: 04-12-2011, 04:15 PM
  5. Tora fork question
    By wanderinginhel in forum 29er Bikes
    Last Post: 01-13-2011, 08:05 PM
Members who have read this thread: 10
