Page 41 of 43 FirstFirst ... 3137383940414243 LastLast
Results 4,001 to 4,100 of 4256
Thread: Surly Krampus
  1. #4001
    Jul 2016
    lastchance - you could always lose the spacers under the stem to get the bars a bit lower.
    Also I recommend a -2 degree headset. This will also drop the front end to increase the extra fork length.
    I am tempted to put the monkey nuts back in the rear drop outs to increase the chainstay length. I know most people want short rear ends but longer chainstays will help with the front rear balance and make it climb better. May require grinding the mech a little to fit the 42t cog but cest la vie.
  2. #4002
    May 2016
    Quote Originally Posted by fartymarty View Post
    Defo have a -2 Cane Creek, needed it to convert the 44mm (straight) HT to tapered of the Manitou (and the older Fox fork prefiously).
    I have probably 5mm on top of the stem and 12mm below it, I'll need to ride a few times to figure out if I need to drop or raise the bars. I suspect since I'm used to a slammed stem I'll hack off another 8-10mm from the steerer but I'm not about to sacrifice steerer length because I "think" the bars need to be dropped without a few hundred miles behind them.
    I've always ridden a slammed wheel but currently have some space because my rear tire has a weird bulge that causes a bit of rub. Rim is true, tire's center line is dead on, both sides. Weird.
    You should get the DT Swiss RWS axles, they're MAGIC and completely negate the need for monkey nuts or other tensioners.
  3. #4003
    May 2016
    Krampus + 140mm w/ 15TA is insane.
    The only real noticeable change (so far) is the bit sits taller at rest, I'll have to futz around with my saddle height/angle and bars to get this dialed in but I'm already in love with this fork.
  4. #4004
    Jul 2016
    Good to hear. I am hoping to get my Pikes cranked up to 140mm before a ride this Sunday.
  5. #4005
    Jul 2016
    Have cranked the Pikes up to 140mm and increased the CS length to 460mm (with monkey nuts re-installed). It goes down faster than the Tories majority in Westminster and seems to climb fairly well as well. It took a little grinding of the Zee mech but the monkey nuts lengthen the rear to offset the increase in bar height. I have mainly ridden down with a few small ups so can't comment on long steep ascents.
  6. #4006
    Quote Originally Posted by lastchance View Post
    I have a Talas 36 130-160 on my Ti Carver and love it! When u take the forks sag into it not so bad, but so much fun. I also used a can creek angle adjust headset slacked it out 1 degree.
    "It Is What It Is" Phil 4:13
    B-Ray Da Beast
  7. #4007
    Reputation: vikb's Avatar
    I didn't love my Krampus with a 130mm Fox 34 on it. It was a bit too tall/slacked out for bikepacking.
    Safe riding,
    Vik
    www.vikapproved.com
  8. #4008
    May 2016
    Quote Originally Posted by vikb View Post
    Yeah, I can see that for sure at 130-140mm.
    I rode an absolutely punishing old OHV trail this morning and had a blast with miles (that's what it feels like at least) of squish up front.
  9. #4009
    Sep 2016
    Is the new Krampus compatible with GX Eagle?
    Reputation: Purdue22's Avatar
    Dec 2016
    Yeah so long as you go with a 30t or smaller chainring.
  11. #4011
    Changing up my Krampus. I sold my Rohloff hub Rabbit Hole wheel. I'll be running a 1x10 or SS setup in the future. The bike is in parts at the moment. I need to get off my butt and get her rolling again.
    Safe riding,
    Vik
    www.vikapproved.com
  12. #4012
    Jul 2016
    Vik,
    Why the change from the Rohloff?
  13. #4013
    Vik,
    I'm not doing the kinds of trips where the use of a Rohloff would be most beneficial - long remote trips where a weatherproof low maintenance hub is key.
    1x10 drivetrains are lighter, cheaper and pretty robust these days. For the 1 or 2 week fair weather trips that I am more realistically going to undertake They are a better fit.
    I've also started thinking that for a lot of the steeper bikepacking I've done I'd be just as far ahead to ride a SS. When trails are so steep it's hard to push your bike up you don't need a wide gear range drivetrain. You are walking up and coasting down so the only place you need to pedal is on flat to rolling terrain. I think a SS setup would be light, cheap and robust for that sort of trip.
    I built up a Rabbit Hole + Hope hub wheel so I can run either 1x10 or go SS depending what makes sense for a specific trip. I could also carry the SS cog and spacers so I could go SS should I rip off my derailleur if that was a concern on a longer/remote trip.
    As an engineer I dig lots about the Rohloff, but I just wasn't doing any trips where it was justified.
    Safe riding,
    Vik
    www.vikapproved.com
  14. #4014
    May 2016
    Survey says: 140mm travel makes for faster descents, my DH times are getting destroyed with this new fork.
    Ascents though? Struggling.
    Why?
  15. #4015
    Why?
    The longer fork rotates the whole bike backwards. That changes your riding position. It worst on climbs because your putting less and less weight on the fork so it gets longer as it will have less sag.
    I had to change my stem and bar position with a 130mm fork vs. stock rigid.
    Safe riding,
    Vik
    www.vikapproved.com
  16. #4016
    May 2016
    Ahhhh, gotcha. I've only put down 70-80 miles and haven't much futzed around with my positioning up front, perhaps it's time?
    On the 100mm fork before I was running 100% slammed but only out of necessity (the steerer tube had been hacked short by the previous owner), I was quick on climbs with that. Maybe I need to drop my bars a bit, at the moment I have 25-35mm of stack, which is a lot, the bike already feels tall enough with the longer travel so on flat ground the bars feel sky-high for sure.
  17. #4017
    Jul 2016
    lastchance,
    It is because the front is higher and you have more weight on the rear. It is the reason XC racers use negative rise stems.
    This is the reason I have added the Monkey Nuts in the rear of my frame. It lengthens the rear and stops the front popping up so much (still to be properly tested but that's my theory)
    Things that will help : flat or low rise bars, a longer stem (I am now up to 50mm from 35mm), slamming the seat forward on the rails, maybe a -2 degree headset as this will drop the front slightly.
    It's all a balancing game between ascending and descending. For me the issue with my Large Krampus is that it could do with a longer reach and steeper seat tube. Your weight is then balanced over the middle of the bike and it will climb and descend well. But saying that it is a 2012 bike and things have moved on a bit since then.
    Let us know how you get on.
  18. #4018
    Jul 2016
    lastchance - also lose the spacers under the stem as that will put more weight on the front. also thinking about it a -2 degree headset will slacken the HA but also steepen the seat angle which should transfer weight forward.
  19. #4019
    May 2016
    lastchance,
    Thanks for this.
    I have a box of stems, perhaps before hacking off another inch from the steerer I'll experiment with stem length/rise, stacking on top of the stem to drop the bars, etc. I really like the factory Salsa whatever-they-are bars that are wide and flat, have some risers but my shoulders are too broad to feel "stable" with 650-680s.
  20. #4020
    Jul 2016
    Vik - interesting on the Rohloff.
    I used to be of the opinion that gearboxes (and good IGHs) were the holy grail of mountainbiking but have recently have changed my mind due to a few reveiws on Pinion gearboxes. I had the Krampus set up as a single speed over winter and it was a revelation - it felt very efficient and mad you ride faster as you had to attack the hill to make it up them. I currently running 10 speed though as it's cheap and works relatively well despite the UK mud.
    The beauty of the Krampus is it's so versatile. I guess 4000+ posts are testament to this.
  21. #4021
    Jul 2016
    yeah wide bars help too. I'm on 780s but have pretty wide shoulders. I was riding a mates 740s over the weekend and they felt narrow.
  22. #4022
    May 2016
    Dropped on the stock 80mm stem, flipped, fully stacked with like 40mm of spacers - seeming solved my problem with a much more forward reach - down over the front end (again).
    We'll see if this helps with climbing.
  23. #4023
    Jul 2016
    140mm Pikes. HA is about 64.5.
  24. #4024
    Dec 2016
    How did you come about 64.5 HA?
  25. #4025
    Jul 2016
    -2 degree headset and 140mm forks. It is probably about 65 as I have just compared to another bike with a 64.5 and its marginally steeper.
  26. #4026
    Dec 2016
    Thanks for the response man. I definitely am not starting an arguement/that is not what my comment is intended to, just trying to figure out if it is actually 65 HA how that happened? The legacy Krampus has an original HA of 69.5 right? So with the -2 degree headset that gets us to 67.5. Then the 140mm which is 20mm more travel than the 120mm it was based upon stock wouldn't that only get you to 66.5 (0.5 degree per 10mm)?
  27. #4027
    Jul 2016
    I did measure it off a photo so there maybe a little error. The stock rigid fork has a 483mm AC (which gives the 69.5HA), the Pike at 140mm is 550mm, therefore 67mm extra.
    I will do a little maths and drawing and see what I get.
  28. #4028
    Big Boy
    Reputation: texasnavy05's Avatar
    anybody know if the new large frame has braze ons for 2 bottle cages inside the triangle? pictures just seem to show one.
    Sent from my SAMSUNG-SM-G930A using Tapatalk
    -It's time to shred some mild to moderate gnar!!
  29. #4029
    Dec 2016
    2017 Krampus size Large. See picture floor question above.
  30. #4030
    Big Boy
    Quote Originally Posted by Purdue22 View Post
    thanks for the post. thats not what i was hoping for. why get rid of the bosses on the seat tube? i dont wear a pack and i need two bottles...
  31. #4031
    Reputation: ghughes.hesinc's Avatar
    Yes, it sucks... I don't get it, why add fender, rack, anything cage mounts, mounts for everything except a second water bottle inside the triangle...
  32. #4032
    May 2016
    But it has internal cable routing!
  33. #4033
    You can't have everything!
    Safe riding,
    Vik
    www.vikapproved.com
  34. #4034
    May 2016
    -Surly
  35. #4035
    Oct 2011
    Hi. I am new here.
    Few months ago got a rather doubtful blue krampus second hand.
    I learned that its a 16". Though the engraving on the bb shell says M12****** hence an M from 2012.
    Its blue. The previous owner mentioned it as a prototype(?)
    The blue he said is original.
    Any thoughts or valid info?
    Aug 2005
    Quote Originally Posted by tedi View Post
    Hi. I am new here.
    One of Surly's recent blog posts indicates that the first prototypes were blue, so it may be legit.
  37. #4037
    turtles make me hot
    Reputation: NYrr496's Avatar
    Quote Originally Posted by liem View Post
    2017 KRAMPUS UPDATES, OR, IF YOU LIVED HERE, YOU’D BE HOME BY NOW | Blog | Surly Bikes
    Yep. Does it look like this one?
    I like turtles
  38. #4038
    Big Boy
    how exactly do you mount two cages on the downtube? i see there are 3 bosses but i dont see how 2 bottles will fit
  39. #4039
    Reputation: bikeny's Avatar
    Quote Originally Posted by texasnavy05 View Post
    One on top and one on the bottom! There are now 2 bosses under the downtube. Why wouldn't they make three down there right away? From my experience, that under-the-downtube location works fine for bikepacking or mellower rides, but isn't ideal for techy riding. You may be able to get 2 bottles inside the triangle using one of the Wolf tooth B-RAD bases if you're on a bigger frame.
    It does stink that they got ride of the bottle bosses on the seat tube. I'm guessing it has something to do with the bend, shorter seat tubes, and dropper compatibility. If there's room, you can always mount one there using another method, like hose clamps, electrical tape, SKS mounts, etc. Not ideal, but it will work.
  40. #4040
    Quote Originally Posted by bikeny View Post
    I've done days of techy rough riding with bottles under the DT and it's totally fine. Having the weight down low is beneficial. I just use that bottle to refill a bottle mounted higher up as it's not a spot you are going to reach down and grab a bottle while riding.
    You can add a couple bottle mounts to the seat tube inside the frame if you want a 3rd bottle. It's not a big deal. I suspect Surly didn't include brazeons there as that might have interfered with some droppers that need lots of insertion depth.
    Safe riding,
    Vik
    www.vikapproved.com
  41. #4041
    I've broken bottle cages and bottles running them under the downtube on a Jones a few years back. When you need to get over big logs and large boulders they can get smashed.
  42. #4042
    They can get smashed I guess. I've done lots of that. I just lift the bike over the logs and rocks without trashing the under DT bottle. I've never damaged a bottle or cage in that position.
    Safe riding,
    Vik
    www.vikapproved.com
  43. #4043
    May 2016
    So, hydration pack then?
  44. #4044
    I think it depends how and where we ride. I don't want to get off my bike and carry it over logs and rocks all the time, I want to ride over them. Again, I'm talking about general trail riding here. If I'm bikepacking, I'll be more more conservative and then stuff under the downtube is no problem.
  45. #4045
    We just listed a bunch of ways to get another bottle inside the front triangle, did you read any of it?
  46. #4046
    #THELEGEND
    Reputation: Guy.Ford's Avatar
    Maybe this will help, maybe not eh..
    https://www.wolftoothcomponents.com/...e-cage-adapter
    #THELEGEND
    2016 RSD Mayor
    2017 Diamondback Haanjo Trail (Alu)
  47. #4047
    I don't get off unless the obstacle is too big to ride over and I don't see how you are damaging that under the DT cage while riding.
    If you smashed the cage under the DT on the Krampus you would be driving the log/rock into your chainring given where the cage sits. So you are not going to hit it on any log/rock you have a hope of riding over.
    If you are just carelessly ramming your bike into obstacles without a second thought I can see damaging the cage, but if you are doing that and there is no cage there you chain and chainring will get killed instead. So I wouldn't recommend it.
    Safe riding,
    Vik
    www.vikapproved.com
  48. #4048
    Just because it hasn't happened to you doesn't mean it doesn't happen. Yup, sometimes I try to ride over big logs, sometimes my chainring hits those logs, sometimes I crash, sometimes I make it over, sometimes when there was a bottle and cage under the downtube they would break. Therefore I don't run them in that location when trail riding. I'm done with this conversation.
    On another note, I was looking over the Jones blog earlier and noticed the Plus also doesn't have bottle mounts on the seat tube. It does have 2 sets on the top of the down tube and a triple set on the bottom of the downtube.
  49. #4049
    Chairman of the Beard
    Reputation: hirschmj's Avatar
    I can confirm this happens. It's extremely uncommon out here in The West, like getting wide bars stuck between two trees, but when I was riding trail down in The South you'd come across logs all scarred up from chainrings that could absolutely crush a bottle cage down there if you hit them wonky.
    The correct number of bikes one should own is N+1, where N is the number of bikes currently owned.
  50. #4050
    Quote Originally Posted by hirschmj View Post
    ... you'd come across logs all scarred up from chainrings that could absolutely crush a bottle cage down there if you hit them wonky.
    Okay we can all agree that if you ram your bike into obstacles you can damage a bottle under the DT. My solution would be to not ram the bike into obstacles since that's likely to cause issues with your DT even without a bottle mounted there. That seems to be Surly's take on it as well.
    Safe riding,
    Vik
    www.vikapproved.com
  51. #4051
    Check out this blog post about adding riv nuts to the bottom of a DT on a Surly frame for a Salsa Anything cage. Same approach would work on the ST of a Krampus MK3 as long as they didn't interfere with your seatpost of choice.
    https://gypsybytrade.wordpress.com/2...er-and-bigger/
    Of course you'd have to drill holes in your frame. If that bothers you hose clamps would also work and would be removeable.
    Safe riding,
    Vik
    www.vikapproved.com
  52. #4052
    May 2016
    You must be fun at parties. Grump.
  53. #4053
    And you must be one of those people that asks a question and then doesn't listen to the answer...
  54. #4054
    May 2016
    For suggesting a hydration pack?
    Side note: you said you were done with this conversation.
  55. #4055
    I was done with the conversation about breaking bottle cages mounted under the downtube!
    I hate hydration packs! It's so much nicer riding without one, especially when it's 95 deg. with 98% humidity!
    I don't know if I'd go as far as drilling holes in the seat tube of my new frame though...
  56. #4056
    May 2016
    I feel ya, I hate hydration packs with a passion, I rode with one for a few seasons before ditching it for regular bottles... Then again, I have an OG Krampus, not the silly new one with no mounts. Haha!
    I wouldn't mod my frame for bottles, either.
  57. #4057
    I did the same, Camelbaks for a few seasons and then back to water bottles. I don't have a Krampus at all, but I do have a 29+ Waltworks, and you can bet it has mounts on the seat tube as well as above and below the downtube.
    If I had a frame I needed to add mounts to, I would use either these:
    https://www.amazon.com/SKS-Germany-1.../dp/B00ZFHW1MI
    or the King USB mounts:
    King Cage - Bicycle waterbottle cages handmade in Durango, CO
  58. #4058
    turtles make me hot
    I use the SKS mounts to put an Anything Cage on my fork. They work surprisingly well.
    I like turtles
  59. #4059
    I visited The Broken Spoke shop in Santa Fe yesterday looking for a new bike for my 10 year old son. Found a nice Jamis 26" disk on sale. Talked to the salesman about me needing a new bike soon to replace my 2003 Fisher 29er. Test rode a med '17 Krampus. I'm like it a lot.
  60. #4060
    Jul 2016
    Gary - You can't go wrong with what is probably the most versatile bike ever made.
  61. #4061
    I'm trying to decide between the 2017 Krampus and Karate Monkey. Been forever since I've bought a bike. Can someone explain the advantages/disadvantages of both wheel sizes (27+ vs 29+)?
  62. #4062
    May 2016
    Quote Originally Posted by Gary in VA View Post
    100% preference, imho. What's your riding style? Where are you riding? How often? Terrain? These are all questions that will be asked.
    With that, I don't know that you'd miss one if you chose the other, i.e. - there's no bad decision between a KM and Krampus.
  63. #4063
    I'm an old, fat man who will be plodding along the trails of the northern New Mexico mountains (Los Alamos). I do enjoy going fast every now and then but it's not what will keep me on the bike, getting exercise and enjoying the desert will do that. I've been off the bike for several years because of arthritis but I have that under control now with diet. Will be riding 2-4 times a week (have trails within 100 yards of my front door). I plan on getting a rigid build first and after I've built up some fitness will add a suspension fork. I'm 5'8" and have ridden a 29er in the past (15.5" frame) and have thought that I might be too short to ride that big of a wheel.
    Anyway, I have a couple months before the funds are available for a new bike so I have time to figure out what to get. Thanks for the help.
  64. #4064
    Ride On
    Reputation: geraldooka's Avatar
    Surly Krampus
    You're well within the height range to have plenty of fun on a 29+ I'm under 5'8" and ride a medium Krampus for mtb riding I run a 50mm stem and 750mm wide smooth move bars with 75mm rise. The Krampus is the most versatile bike I have ever owned and remains my favourite bike. 27.5+ does not offer the same roll over and momentum that 29+ has. Having said that I'm fortunate to run super light carbon rimmed wheelset tubeless which eliminates the comprises of weight for 29+ its like having my cake and... Bottom line I wouldn't consider your height as a factor in your choice.
    Michael
    Ride on!
  65. #4065
    May 2016
    You'll quickly outgrow a full rigid bike if you go Krampus. Also, please be aware of how tall any sus fork at or over 120mm will make the Krampus. You might have the perfect cockpit with the stock rigid fork but once you add a bunch of CTA mm, you're all of a sudden on a penny farthing.
  66. #4066
    NO! There are plenty of people here who have not 'outgrown' a rigid bike, it's all about your needs and wants. Many people do not need any suspension, but end up with a FS bike because that's what everyone tells them they are supposed to have. I've been happily riding without any suspension for at least the last 10 years, and my local trails are anything but smooth. I decided a long time ago that I'd rather slow down a bit for that rock garden in exchange for a lighter, simpler, more efficient ride. And no, putting a suspension fork on a Krampus will not make it a Penny Farthing. A 100mm to 120mm fork will not change the geometry much once you factor in fork sag. That's why it's called a 'suspension corrected rigid fork'!
  67. #4067
    May 2016
    Im not going to argue with you again, so okay, you win.
    Take shit for face value, man. Im not steering him any direction other than the path Ive taken, I guess next time Ill add YMMV.
  68. #4068
    Reputation: gooseberry1's Avatar
    Mar 2016
    Hold up I love my krampus for my weekly rides with groups and going up to the Mesa and only ride the easy bike when needed for long days in saddle. People bikes are for fun and I will not sell the krampus because it's that bmx bike I had as kid with gears. Oh ya I just did my first ride on a deadwood and it was pretty nice.
  69. #4069
    meh... whatever
    Reputation: monogod's Avatar
    Feb 2006
    100% bovine excrement.
    for starters, the proper nomenclature is "rigid bike". "full rigid bike" is redundant.
    hardtail = solid frame with squishy fork.
    full squish = self explanatory.
    rigid = hardtail frame with rigid fork.
    next, the thousands of people riding a rigid krampus in the gnar are proof it's not quickly outgrown. a rigid krampus is an absolute blast to ride! a 3.0 tubeless tyre soaks up an amazing amount of trail static.
    finally, a 120mm squishy fork on a krampus will not result in a penny farthing. in fact, it will handle exactly the same as the stock rigid fork because the stock fork is 120mm suspension corrected.
    "Knowledge is good." ~ Emil Faber
  70. #4070
    Jul 2016
    It's not that you can't ride a rigid Krampus in rough terrain because you can. I would be more than happy to ride a rigid Krampus down a WC DH track but it will be a lot faster with 120mm (or 140mm as some of us have) up front.
    For me it is how much you can get out of a 29HT.
    Its the same reason I am using 2.4 Minion DHR2 as they're faster than plus tyres when you are pushing it hard.
    I get why others run their Krampusii rigid and SS... it depends what you are into and ride.
  71. #4071
    Big Boy
    if the karate monkey fits a 29x3 tire, what is the argument to get a krampus? i realize there is a bit more clearance, but i never ride in mud and will mostly be on buff singletrack. and, id really like to have the extra water bottle cage bosses
  72. #4072
    Jul 2016
    Texasnavy - Geometry maybe?
  73. #4073
    Reputation: bubba13's Avatar
    Krampus owners will enjoy more BB drop and can run the rear axle nested tightly against the front of the dropouts with 29+. The RED also happens to be the best Surly color currently offered.
    More water bottle options? You can add two to the fork if needed.
    Portland Off Road Navagators
  74. #4074
    Big Boy
    Quote Originally Posted by bubba13 View Post
    i really prefer 2 bottles inside the triangle i know its nit-picky. and wouldn't mind trading a slightly higher bb and slightly longer chainstay for the extra bottle.
    so i guess ill be alright with it. i do like that red though...
  75. #4075
    The red in person on the new Krampus is pretty eye popping. I like it and I don't really care for red bikes.
  76. #4076
    Jun 2017
    I was just about to say the same thing. I'm getting ready to do a custom build on my 2017 Krampus frame and the red paint is stunning.
  77. #4077
    Dec 2014
    Same here. I'm not really a red fan but I'm really happy with how my Krampus looks especially with the polished components.
  78. #4078
    Jun 2017
    Looks hot. Nice work. Can't wait to get mine put together.
  79. #4079
    Reputation: noosa2's Avatar
    My LBS said it would be 6 weeks or so before they can get a large Krampus frame and it looks like Bikeman does not have any in stock either. Anyone know of any other online store that has a large in stock?
  80. #4080
    It looks to me like the new Karate Monkey also doesn't have bottle mounts on the seat tube. Disappointing!
  81. #4081
    Big Boy
    xs-m dont have them on seat tube but large and xl do.
  82. #4082
    Gotcha, just found that in the frame highlights section. Still don't understand why Surly wouldn't do the same on the Krampus. Looking at the geometry charts, there isn't much difference between the 2. The biggest is the BB drop, which is 10mm more on the Krampus. The KM chainstays are listed as shorter, but I suspect that's at the shortest setting, so to run 29x3 tires you would have to run it longer,
  83. #4083
    Big Boy
    i think they wanted more insertion depth on the krampus for deep seated dropper posts. thats the only reason that would make sense to me.
  84. #4084
    Last time I checked, the frame highlights for the Krampus also stated three bottle mounts for the L and XL... I would question whether the KM actually has them. Fore sure, my XL Krampus does not.
  85. #4085
    Big Boy
    Quote Originally Posted by ghughes.hesinc View Post
    the picture of the purple km on surlys website has them on the seat tube. not sure if that is going to carry on to all frames though
  86. #4086
    Oct 2011
    Have i asked this question before?
    Has anyone put 27.5+ tires on krampus and compare the ride with a karate monkey 27.5+ ?
  87. #4087
    Reputation: BmoreKen's Avatar
    Sep 2004
    My LBS shows they're out of stock. Anyone know what the deal is? When will they be releasing or restocking? I need a large, dammit!
  88. #4088
    One thing's for sure, it's going to have a really low bottom bracket!
  89. #4089
    Dec 2014
    I intend to try it. The Krampus was supposedly designed around being able to run 29+ or regular 29ers. Therefore a 27.5+, being roughly the same diameter as a 29er, should still work.
  90. #4090
    Jul 2016
    Krampus 69er
    It is funny that 275 is mentioned as I have just stuck a 26 on the rear. It's mainly as a joke but I am willing to give it the benefit of the doubt and take it out of the garage for a carpark test.
    I have been following the Geometron thread (on mtbr) and they have been using 29F 275R with a lot of success and intuitive steering.
    I think though with a hardtail you need a bigger rear wheel to get over the bumps. As such I am sure that the 29 will be going back on the rear. Plus I am sure I would get some silly looks if I took it out for a proper ride.
    Sorry forgot to mention it has a 63.5HA and 305mm BB. Low and slack boxes ticked.
  91. #4091
    Jul 2016
    I have been running my krampus 650B Plus rear with 29 Plus front. It works really well. My bottom bracket height is dead center at 13 with 3.0 tires. As far as bottom bracket being to low if run 27.5 plus all around, not so sure would be much lower than some of these other new 27.5 Plus bikes out now that are running close to 12.0 bb height, like the pedalhead or kona honzo. If I went 27.5 plus 3.0 tires with my reba 120 fork, doing the math would drop my bb to around 12.25 from my current setup. If you need more clearance, throw a 130mm fork and bike would probably be golden!
    I still cannot get over how much I love my krampus, did a 3 hour ride yesterday and amazes me how it can eat up the chucky stuff, but still can move it around when needed and climb switchbacks.
    Attached Thumbnails Attached Thumbnails Surly Krampus-2017-03-27_20.39.09.jpg
  92. #4092
    Jun 2017
    Quote Originally Posted by SSsteel4life View Post
    What fork are you running?
  93. #4093
    Nov 2016
    I love my Krampus. It doesn't excel in everything, but man it sure is fun.
    I would like to get my leg over a new frame and see if its something worth changing.
    Hi. I am new here.
    Blue is a QPB employee color code. So when the Krampus was released the Bass Boat green was quite expensive so if someone was going to get a pro deal on one it was the "Bruised Baby Blue" to keep the cost down.
  94. #4094
    Jul 2016
    Wow that Blue is nice. Is it metallic? Do you have the RAL code for it?
  95. #4095
    Nov 2016
    It is not Metallic, and I don't have the RAL code for it.
  96. #4096
    Jul 2016
    Getting my hands on a Krampus frame next month as soon as they land and looking on building it a SS. Now being a noobie and not getting my head around mech stuff too well, the question is what would be a recommendation for the chainset/cranks/front ring? Mr. Whirly? RF Narrow Wide? Something else? What do I need to take in consideration? Going with size L, being 6'2" with a 37" PBH and with no wish to be too stretched over. Pretty much got the build list covered, but still to figure out the drive train, only to know that it will be a SS for now and maybe a Rohloff later on.
  97. #4097
    So many options. Check out two fish for putting bottles anywhere. Stem cage, back of seat cage, 2 bottles next to each other cage. Topeak and other can fit a 48 oz bottle to their cages, feed bag on the handlebar or top tube......
  98. #4098
    Red? I'll take your red and top it with a lemon lime pearl with my 1x1. IMHO.
  99. #4099
    Big Boy
    i really wanted 2 bottle cages inside the triangle and was looking at the karate monkey. turns out a chupacabra will fit in the karate monkey. so for a slightly higher bb i can get my braze ons. still debating what to do though.
  100. #4100
    Older KM owner here. 29x3 will fit in the back? Hmmm. Running front der, fender and rack, that might need to change I'm guessing.
Members who have read this thread: 555
