Page 18 of 79 FirstFirst ... 81415161718192021222868 ... LastLast
Results 851 to 900 of 3916
Thread: Surly Krampus
  1. #851
    Just finished my build today. It's an XL and it came in at about 30 lbs.
    It's a suicide-shift 2 speed. Basically a single speed but when I need it I can kick down (literally) from 36-19 to 22-19 to power up the big hills we have around here). I've run this set-up on my commuter for a year now and love it.
    Specs:
    - Surly MWOD double front (36 and 22)
    - ghetto-tubeless
    - AVid BB7 180mm front and rear
    - paul's singlespeed rear hub
    - Paul's melvin chain tensioner
    - white industries eno 19t
    - thomson seatpost
    - crank brother's candy pedals
    - precision handlebars (super wide) and grips
    - temporary kona stem
    I'll probably trim the handlebars a few inches, and once I get a few rides in I'll decide what size stem I need and place a matching thomson stem on there. and i'll chop the steerer at that time too!
    I've only gone up and down the block a few times, but this is definitely a much different animal then the Pugsley I just sold. I'm looking to find a suspension fork for it once I'm comfortable with the options that present themselves.
  2. #852
    So I don't get tire flats on my local trails. Period. Knock on wood. I've run a tubed fat front for almost a year now. No flats. Taking flat prevention out of the equation, is there a good argument for running the Knard/Rabbit Hole gorilla tubeless? I can't imagine the weight savings are that great. Low pressures are nice, but I haven't had trouble with pinch flats on my 45 North fat front running Q tubes. I have a Rabbit Hole 120tpi Knard front wheel/tire coming this week. With my practical experience, I could go either way with tubes or tubeless. But I could be missing the obvious. Anybody care to share any wisdom?
  3. #853
    Reputation: dvo1's Avatar
    Quote Originally Posted by bluestatevirgin View Post
    Running my Husker Du tubeless I saw a 2 once difference in weight which can be more I just didn't have the right rim strip to loose more weight, ride wise though you could feel the tire felt like it had less air in it then when you have a tube, i.e. 10psi feels like 8psi, which of course sounds stupid, but that's what I can say.
  4. #854
    Reputation: thickfog's Avatar
    Oct 2010
    Re: Surly Krampus
    Depends on the tubeless setup and the tube setup you came from.
    Look at both ways as a system.
    Both need a rim strip with drilled holy rims. Now, you can use something heavy as hell like the Surly rim strips or something light like one or two rolls of duct tape. This also gives design choices as you can run the tape inside out and show off the tape pattern /design.
    For a rim strip, I am using a poly-type designer tape. It's light as heck and super strong.
    So there with tubes or tubeless you can save a little weight and make your rims look cool.
    Onto the tube part. You can use the heavy Surly toob or use a regular 29er tube. Now, depending on your trails, stretching a 29er tube to fill a 3 inch tire, may lead to flats quite fast. Only you can be the judge on that.
    So, depending on tube used subtract that weight for tubeless and then add:
    weight of the stans (mine weighs 1/2 oz) or duct tape for rim sealing tape, the valve stem (mine weighs less than 1/4 oz) and AT least 2oz of sealant for a tire this large. Most people use 3 or 4 oz. I don't. That's talked about in another thread.
    Also some people have a hard time seating the bead tubeless and resort to foam in the rim channel. It weighs nothing though. But whatever, any weight must be added.
    So add the tubeless setup weight and what have you really saved... Maybe 1-4 ounces given the variables I've stated. So that would be 2-8 ounces for the total. That goes from 2 oz (worthless) to 8 oz (which is quite wishful really) which is worth it.
    My point is there's too many variables on any given setup to give a solid weight loss figure.
    Combine this with tubless issues: burping, possible bead unseating on the trail making it very hard to reseat, air loss until the tire is well coated with stans, flats on the trail still and no backup tube if you take that kind of chance.
    So, yes I run tubless (and no spare tube in my pack. It has left me walking once in 5 years) to save those few ounces, but like dvo1 said 10 psi feels like 8 and rolling resistance feels less with tubless. It may be in my head, but if this is what it takes to trick myself, then so be it.
    CRAMBA Chairman
  5. #855
    Reputation: vikb's Avatar
    I rarely got flats on my MTBs with tubes. Like less than 1 per year. Switching to tubeless my wheels are lighter which is nice. I get better traction and less rolling resistance. I can also run low pressures without worry about snake bites.
    I carry a spare tube in my hydration pack, but I've never had a tubeless failure on the trail.
    I've switched my 2 main MTBs over to tubeless and won't go back. Thinking of setting up my fatbike tubeless as well.
    Forget about the weight and think about allowing your tire to conform more easily to the terrain without having that tube in there. That extra traction/performance from your tire is worth it.
    Safe riding,
    Vik
    www.vikapproved.com
  6. #856
    Dec 2010
    Quote Originally Posted by vikb View Post
    +1 to this. This is nearly identical to my experience and opinions on tubeless.
  7. #857
    Reputation: modifier's Avatar
    I heard yesterday that these rims are only 670grams. That's crazy light for that width. Have others weighed their rims? How about a weight on the production tires? 120tpi.
    No it never stops hurting, but if you keep at it you can go faster.
  8. #858
    Dec 2010
    I haven't weighed anything except the complete bike, but the rims did feel very light. I was definitely surprised by the weight.
  9. #859
    Oct 2010
    Re: Surly Krampus
    Quote Originally Posted by modifier View Post
    Mine came in at 653 grams.
    CRAMBA Chairman
  10. #860
    the mountian is within
    I have one good offroad ride in finnaly-and was impressed again! Loved it on the test last summer-but really loved it at home! Did a very rocky trail-rock crawling type. Found that the front lifts real well for such a big bike-and the slack head angle was awesome rooling off stuff-when i didnt get the front up! A buddy said it just looked easy-like I was on an easier trail.
    A note about tubes/tubeless........Remember if you run tubes to talc or babaypowder the inside of the tire well. It is kind of forgotten to do this it seems. If you have the tire and tube talced well-they CAN move independently...it feels more like tubeless.
    i own a bikeshop in WV thetruewheelwv.com
  11. #861
    Most rim weights I've seen for the Rabbit Hole in this thread, and others, have come in under 700 grams. The 120tpi tires seem to be all over the place, from 700 to 1100grams. The most common weight reading I've been seeing for the 120tpi Knard is between 950-1000.
  12. #862
    I mounted my 120 tpi Knard yesterday and did not like the way the bead seated, it popped off on both sides the first time I aired it up; it popped at 25psi, so not a lot of air.
    I'm using a Nimbus Dominator 2 rim, 42mm, burly rim hook, so I was kinda suprised the tire popped off so eailly. I also like running tubeless, and had planned to run tubeless on the Knard, but not any longer. Maybe the 27tpi is burlier constructopn and/or has a tighter fit, but this the ultraligt casing and it fits big, so I see this tire blowing off the rim as a tubeless set up.
    I also have a Knard 26 x 3.8 120tpi and it appears to have a standard Surly casing, feels more substantial, though it also weighs more at 1325gm.
    My 29 x 3 120tpi Knard weighs 925gm, kinda heavy for what it is, only ten percent larger overall that my Hans Dampf 2.35, far less burly, and heavier by 50gm.
    Anyone have a 27tpi Knard comparison to a 120tpi? How does the casing and rubber differ? What's the weight range for the 27tpi?
    Not impressed so far...
  13. #863
    Quote Originally Posted by sasquatch rides a SS View Post
    Thanks to everyone above for the tubeless responses. I worried I might be opening the old tube vs. tubleless can or worms--I generally go tubeless, but not for my fat front which I never bothered to set up tubeless. I wasn't sure if these fatter tires might fall somewhere outside the tubeless argument folks have on "regular" tires. By the way, for those who are thinking of using tubes, I've had just great luck and performance from q-tubes. Running the q-tube at really low pressure on the front, and it's been pretty perfect.
  14. #864
    Quote Originally Posted by Nurse Ben View Post
    I have 27tpi f and r. I set up the front tubeless, but ran out of foam for the rear. When inflating the tubed rear I had 1 issue with the bead popping off around 12 psi; had to let air out and reseat the bead. Going tubeless w/ 24" split q-tube, had to use foam to create seal/push rim to sidewalls. Very loud snapping of bead onto rim. W/ no sealant very little air leaking out! Burped 1 time so far, so running higher air pressure. Burping isn't a good sign! I'm running a slime tube in the rear and it seemed to even recover from a pinch flat, to my surprise. But pinch flat wouldn't be an issue with tubeless, which is what I have exclusively run on mtb for the last 2 years. I'm ready for a successor to the knard. Something like the bud and lou for tread, but a 3.2 or so up front!
    Cross laced wheels have ~40 miles on them and they're still running super stiff and super straight. I love how stiff this bike is, I would be curious to compare to a regular laced krampus.
  15. #865
    Feb 2012
    so how many people are running normal 29er tubes vs the surly tubes? any issues? i was looking at running standard schwalbe 29er tubes or the q tubes superlite ones. is it worth it or is it more reliable to run the Surly tubes??
  16. #866
    Quote Originally Posted by SteveJfromtheSwitch View Post
    As I mentioned above, I have been running a q-tubes superlite on my fat front bike for almost a year with no issues. I'll take the weight savings myself.
  17. #867
    Quote Originally Posted by thickfog View Post
    Thickfog, you're using tape as a rim strip. Are you using two pre-measured strips of tape placed sticky-side together to create a rim strip?
  18. #868
    Oct 2010
    Re: Surly Krampus
    For my uma 90 mm rims on my fat bike, yes two pieces of designer duct tape side by side sticky side out. I did not cut this tape as I preferred the slight overlap for strength. This was a pain to set up. One year two months still ok.
    For krampus, just a single piece sticky side out, but I cut the width down as the poly tape would not conform to the center channel well. This makes me a bit nervous as the tape edge is closer to the rim holes. My fear is the tape may push through the holes one day if it shifts. :banghead:
    CRAMBA Chairman
  19. #869
    The surly rimstrip has this same problem! If you don't pay close attention, its easy to end up with the tube protruding from the cutouts! The strip should be about 1cm wider imo.
  20. #870
    Oct 2010
    Re: Surly Krampus
    My different tapes :
    From left to right :
    Green sparkle poly tape. Rim strip. From
    tapebrothers.com:
    http://www.tapebrothers.com/mobile/default.aspx#P2998
    Duck brand tape. Rim strip.
    Gorilla tape. Rim sealing and rim strip.
    Giant stan's tape at almost 4 inches wide! Rim sealing.
    The fatbike with uma 90s tubless. Rear uses gorilla as sealing tape, front uses giant stans (giant stans was found later). I prefer stans as it stretches and conforms to the rim crevices better:
    CRAMBA Chairman
  21. #871
    American Made!
    Reputation: 1x1clyde's Avatar
    One more "mod" I had to try
    White Bros Carbon Fork, 490 Axle to crown keeps it slack!
    So with the Rabbit Hole rims, 120 tpi Knards it is at a svelte 27 1/2.
    I've always liked carbon with my rigid set ups and the addition of the bigger tire is a perfect match. Had some pretty fast runs down some local trails the last few days and expect for the really rocky it was just fine!
    What is thy bidding, my master.
  22. #872
    I have the Knard 29 x 3 (120tpi). I run Maxxis Freeride Tubes 26 x 2.2-2.5 (295gm) in all my tires, 26 x 4", 29 x 2.4, and now 29 x 3". Reasonable weight, no pinch flats to date, less expensive and more durable than the Surly offerings. Be sure and preinflate the tube to stretch it out, use some powder so the tube moves in the tire.
    I rode hard today, found the pressure sweet spot pretty quickly at 17psi with ambient air temp around 40 deg F. Rode a lot of rock, some mud, roots, drops up to 2', had a minor rim shot off one biggish ledge where I landed sideways, it would probably have been better with a little more pressure, but more pressure = more bounce.
    Overall I like the tire, it's faster rolling that an Ardent or Hans Dampf, not quite as competent in mud, but then what is... The tir needed some breaking in, initially a little squirelly, but once it got dirty it was all good. The volume is very obvious, far more cushion than a 2.4, easier on my back and butt, was able to ride longer and never felt beat; the HD always leaves me feeling beat up.
    I'd be curious to see if the sidewalls are beefier on the 27tpi, anyone have both tires in hand to do a comparison?
  23. #873
    Thanks. I haven't set up a cut-out rim before. I'm not going to use the Surly rim strip. I wasn't sure if using the tape sticky-side against the rim and with the sticky open to the air outside the rim in the cut outs would cause some kind of problems. Either as dirt collectors, or a sticky mess on hot days. Plus, with regular gorilla tape it'll be kind of ugly. I'll figure it out.
  24. #874
    Oct 2010
    Re: Surly Krampus
    I meant sticky side out as in when you are looking at the rim channel. Then sealing tape over that. You don't want sticky tape exposed to the outside. That would be some mess.
    CRAMBA Chairman
  25. #875
    Yep. Got it. Common sense, right? Now I'm just looking into a couple different methods.
  26. #876
    Oct 2010
    Re: Surly Krampus
    Yeah kind of common sense. Some people have tried sticky outside and just let the dirt collect. After a certain point, the tape is nicely coated. I've also heard of coating the exposed tape with glitter. Now that might be cool.
    CRAMBA Chairman
  27. #877
    Nov 2008
    Update on my tubeless setup...
    45mi shredder ride 4k climbing in goathead central Tucson Az &
    2 day bike-packing ~40mi on the Black Canyon Trail which has some gnarly tire flattener sections.
    ...still holding awesomely with the 26" split tube setup and no tape!
    Also, unless you're doing mega-drops and DH sections, this thing handles about the same as my Kona Unit with a F29!!!
  28. #878
    Feb 2012
    did you use any foam under your split tube? width?
  29. #879
    Quote Originally Posted by robothouse View Post
    crazy, mine required foam (for floor pump bead seating) and keeps burping at moderate pressures, and I've only set it up tubeless in the front! 27tpi tires. The tires weren't all that easy to get on the rim either.
  30. #880
    Are you saying you have the split tube right up against the bare rim?
  31. #881
    Jan 2013
    Where do you guys see this new tire size going? Will there be more offerings or is this going to be it for tire selection? I like the idea of being able to use standard bike stuff and and getting some "fat bike" benefits.
    Also,
    Has anyone tried running their Krampus with normal 29er tires and wheels? Did you get a lot of pedal strikes? How low was your BB? Got a pic of the chainstay clearance in the rear with the knard and normal 29er tire? I am thinking that this might be just the ticket for a winter bike, if there is enough tire clearance.
  32. #882
    Dec 2010
    I know I've said it numerous times, but I hope Surly makes a 29x3" Nate
    I would like to see a regular 29" tire mounted on the Rabbit Hole. I like the look of regular (2.2-2.4 width) tires on wide rims. I kind of wanted to build up a Karate Monkey with a Rabbit Hole wheelset and 29x2.4" tires to see what it was like if I didn't get a Krampus.
  33. #883
    Baby Bear is in the house
    Reputation: r1Gel's Avatar
    Fox fork???
    Can we please have a photo of the tire clearance on that Fox fork? What rims are those?
    Better to have and not need it, than to need it and not have it.
  34. #884
    Quote Originally Posted by r1Gel View Post
    There are multiple pictures of the fox fork tire clearance in this thread already.
  35. #885
    Feb 2005
    I know I've said it numerous times, but I hope Surly makes a 29x3" Nate.
    Agreed on the face of the idea. However, the Knard is a decent rear tire already, what's needed is a front specific tire, so my vote would be, bring on the 29x3 Bud!!!!!
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
  36. #886
    Sorry. I haven't had the time to go through all 29 pages of this thread.
  37. #887
    Let me google that for you
  38. #888
    Quote Originally Posted by ntm1973 View Post
    The development of fat bike 26 x 4" rubber gives you an idea of what will happen. Surly ran with one general purpose tire for a few years until sales of fat bikes grew the market. Then they released a 2nd tire and then several tire options. Now you have a at least 1 non-QBP company [On One] putting out a quality 26 x 4" tire.
    My guess is that Surly/QBP will want to keep the buzz going on the Krampus/29+ idea so I would expect something new every year. They want the forums, blogs and mags buzzing so that the idea catches on.
    That could be a new tire or maybe Salsa will release a lighter AL 29+ bike. Maybe both.
    I think it will depend on sales numbers for the Krampus and also for 29+ tire/rims a la carte.
    To answer your question the other way the Knard won't be the only tire option in a couple years unless QBP is stuck with a bunch of 29+ tires and rims they can't sell. That doesn't seem likely.
    Safe riding,
    Vik
    www.vikapproved.com
  39. #889
    Reputation: ktm520's Avatar
    So you are running a split tube without any type of rim strip under it? My Knard and RH should be here today It's going on the front of my rigid SS. Going to try it on a P35 while I'm building the RH.
  40. #890
    Reputation: GTR2ebike's Avatar
    May 2010
    wouldn't shock me if we saw that this weekend.
  41. #891
    Jon BALER
    Surprisingly enough, the Krampus has a higher BB than a Karate Monkey:
    BB Drop:
    Karate Monkey: 68.0mm
    Krampus: 60.0mm
    Salsa El Mariachi: 60 mm
    So with all equal size 29er tires, the Krampus and El Mariachi will have the same bb height, and Karate Monkey will be lower.
  42. #892
    bhc
    bhc is offline
    Quote Originally Posted by ktm520 View Post
    Please give a review on how the Knard works with the P35.
  43. #893
    Nov 2008
    Sorry folks, I guess I left some info out on the tubeless setup...
    - 120tpi Knard tires (front n rear)
    - no foam or gorilla tape used
    - used Surly's provided PVC 38mm rim-strip
    - used 26" tube split down the middle over Surly's rim-strip
    - 2.5oz of Stan's sealant per wheel... not much, I know... but I'm testing
    - used air compressor to inflate, both wheels sealed bead on the first try.
    - running happily with ~13psi on trail rides, holds air even overnight in sub 32F while bikepacking
    - brings 2 tubes for backup on rides, but am starting to feel pretty comfy with this setup after +100mi
    Everyone else I've been reading online use variations including foam, gorilla tape, 24" tubes, etc... these may provide added longevity, but time will tell.
  44. #894
    Could someone with a medium Krampus measure the dimensions of the interior of the front triangle [ie. the size of a frame bag] pls?
    Safe riding,
    Vik
    www.vikapproved.com
  45. #895
    Thanks robothouse.
    Got my Knard 120 and RH today. Knard weighed 970g and RH was 700g. Don't have spokes or a hub yet for the RH, but I mounted the tire on a P35 and the RH with a tube. At 20psi, the tread width was 74mm and 74.5mm respectively. I was also able to get the tire to easily bead tubeless on the RH with just one wrap of clear package tape using a compressor. Was planning to use a 24 split tube but after this test I think I will mount it with just tape.
    At low psi, I think you could get away with running a split tube without a rim strip/tape.
  46. #896
    Reputation: miles e's Avatar
    Aside from the minor difference in width, is there much of a noticable difference in profile between the tire on the two rims? I mounted a Knard on a P35 and the profile appears quite "eggy" (i.e. tall with substantial drop from the crown to the edge knobs). The pics I've seen of the Knard on a RH look similar, but a side by side comparison would be great.
  47. #897
    miles e, I'll take some pics of the two later this week. I honestly didn't really pay any attention to the profile between the two rims. If I get the RH built before the weekend, I probably won't even try the P35 first.
  48. #898
    Cool. I'm sure the RH is the optimal rim for the Knard, but I have a few reasons for wanting to use the P35 (which Surly did say was okay) so long as it doesn't handle to wonky. Maybe the low pressure will flatten the tire out once on the bike and negate some of what I'm seeing, but it seems like the cornering would be weird with such a tall profile.
    ''It seems like a bit of a trend, everyone trying to make things longer over the last couple of years" Sam Hill
  49. #899
    Oct 2007
    Surly Krampus
    Just picked up mine...Surly Krampus-imageuploadedbytapatalk1361332664.163261.jpgSurly Krampus-imageuploadedbytapatalk1361332678.606772.jpgSurly Krampus-imageuploadedbytapatalk1361332700.590640.jpg
  50. #900
    So I've just about concluded that tubeless won't work on these. I keep burping my front wheel unless I run the pressure much higher. Last night I lost so much air from losing bits here and there that I got a snake bite in the sidewall and couldn't get it to reseal and had to stick a tube in. I'm thinking the 27tpi tires are just lacking something that nicer folding tires have. I thought the 27tpi would be more durable and work better for tubeless, just with the weight penalty of the heavier, cheaper tire. I'm disappointed, this will be the first time for me running tubes in a few years!
