Results 1 to 25 of 25
    WNC Native
    Reputation: nitrousjunky's Avatar
    Specialized 29 x 2.6 Purgatory & Butcher Tires
    Some of you may have seen these over on Pinkbike, but sounds like we may be less than a month away from them being available! I've always had good luck with Specialized 29er tires and they seem to be good bang for the buck. I'm excited for yet more great 2.6 options!
    PB Article here - https://www.pinkbike.com/news/keegan...tler-2017.html
    "I ride to clear my head, my head is clearer when I'm riding SS. Therefore, I choose to ride SS."~ Fullrange Drew
    WNC Native
    Looking like the Butcher 2.6 may be a major fail. I have a buddy who picked one up last friday. After a day of sitting aired up to 35psi tubeless, it's measuring 2.3. He's confirmed another local rider is getting the same numbers on his. Anyone out there on either 2.6 tire?
    Dec 2012
    I just picked up a 29" x 2.6 Butcher My un scientific measuring has it between 2.35 and 2.4 Thats on a 30mm id rim. A little heavy at 980 gms for my trails though.
    Jun 2012
    I recently purchased a 2017 specialized with 3.0 purgatory tires. I like the tires but the ride is a little stiff. I understand specialized has increased the sidewall stiffness for people that run lower pressure. I donít run the lower pressure and donít ride hard anymore... rode hard 20 years ago...im 50+, now looking for ride comfort. Looking for 27.5x 3.0 tire recommendations there are not as stiff.
    Jan 2014
    Quote Originally Posted by MTB9488 View Post
    What pressure are you using on the Purg 3.0 ?
    Jun 2012
    Quote Originally Posted by TheBaldBlur View Post
    Iíve tried various different pressures from 9 to 16 psi. I have had Bontrager and WTB Rangers in the past I liked the ride quality but definitely not as Grippy as the purgatory
    Workin for the weekend!
    Reputation: -Todd-'s Avatar
    Mounted up a set of 29 x 2.6Ē Purgs @ 22psi... Measuring 2.39Ē so far. 30mm ID rim...
    Specialized 29 x 2.6 Purgatory & Butcher Tires-4539bc65-ac05-425b-84bc-8cf693700149.jpg
    Todd
    Rider/Builder/Hacker
    Nov 2015
    Quote Originally Posted by -Todd- View Post
    @Todd - any update on your Purgs? Did they expand at all? What's the overall diameter? Would like to know if they'd fit my ACV before I jump in and buy.
    Mr. Buck E. Fikes
    Reputation: Oh My Sack!'s Avatar
    Almost bought a set at Art's last week for $44 ea but the actual diameter is a joke. I can get that volume out if a Schwalbe 2.35 so I didn't bother. I hear its a decent tire in tech, though.
    Nov 2015
    Quote Originally Posted by Oh My Sack! View Post
    Thanks. It's got to be an improvement over the 2.3 Purgatory in terms of width and volume though, right? I've got the 27.5x3 version on the plus wheelset, and thought the 29x2.6 would be good for 29er mode.
    Quote Originally Posted by carbine_275 View Post
    Some stretch, but not 2.6Ē... Iím happy, itís got a pile of grip. Not sure on diameter, never measure that. Tire has 26psi, on a 30mm (Internal dim) wheel
    Specialized 29 x 2.6 Purgatory & Butcher Tires-ceb69021-8892-4fe0-9be7-d227fc7ea122.jpg
    Todd
    Mr. Buck E. Fikes
    I was excited, at first. Grid casing is substantial. Nice tread. Good review from a few of the guys that use them on the particular stretch of mountain I intended....but I want more width out of a 2.6. I just put a DHF 2.5/DHR 2.4 on instead that I know will handle the terrain and has virtually identical actual size. I just get a little whacked over these mfg's nominally sizing their tires as they do only to see them come up so short. When I'm not running the 9'r set on this bike, I'm on 27.5x3.00. I love the volume.
    ^^ what purpose do you ride with.
    Mr. Buck E. Fikes
    Quote Originally Posted by cunningstunts View Post
    😉 That changes on virtually every ride. It's a goal that I have always applied from piloting an aircraft, my sport/tour moto, down to my mtb or road bike. Rather than mindlessly partaking in the activity but instead always recognizing a learning opportunity, small or large, to focus on and practice till mastery.
    Rides all the bikes!
    Reputation: Sidewalk's Avatar
    May 2015
    Just got a 2.6 Butcher. While I really like the grip of the stock 2.3 Butcher, I couldn't understand why they put such a narrow tire on a long travel bike (E29). Before pulling the old tire, I grabbed my caliper...the 2.3 was just shy of 2.1!!!
    The 2.6 came out to 2.3. I'll check again when I get home tonight as I think I'm going to go for a short ride after work and see if it stretched. This is on the stock 29mm ID Roval rim.
    By comparison, the 2.35 RaRa on my XC bike is on a 21mm ID Valor rim, it measures 2.25. So my XC bike essentially has the same size tire as the enduro. That helps explain why it is sub 1000g, which caught me by surprise before I mounted it.
    Mar 2006
    My 29x2.6 Purgatory weighed in at 1020 grams, 120 above advertised weight. It feels pretty tough, and corners well, but is exhausting as a trail tire.
    Sep 2016
    I recently installed a Butcher 2.6 on my Roval 29ID front rim and measures at 2.45mm at 25 PSI.
    This morning I installed the rear 2.6 on the same rim at 30PSI and currently measures 2.35.
    Since the front one has been mounted (tubeless) for about 60 days, I would have liked to see some more stretch.
    I too was surprised the measurements were smaller than expected (and advertised).
    What pressures are you all riding on with these? As I mentioned, I am at 25PSI in the front and will adjust the rear when I am on the trail. Just looking for reference. I am 215 fully kitted.
    May 2015
    I don't have an accurate gauge (it died), but I am probably around 22 PSI. I've 145 pounds. Unfortunately, I seem to find that it doesn't matter if it is a 2.6 (*cough* 2.4 *cough*) or 2.1, I can't run less than 22 up front on any bike (My XC HT is the same).
    But overall, I really like it. I did a 25 mile, 4200' ride the other day with some real sketchy stuff and it was great. 160 miles and 25,000' in three weeks so far on the tire.
    Reputation: bikeny's Avatar
    Pretty disappointing that the Specialized '2.6' tires are smaller than other manufacturers 2.4 and 2.5 tires, especially at those high PSIs. Looks like they will be scratched from my list!
    Mr. Buck E. Fikes
    It's actually pathetic with so many of these nominal sizes from Specialized and Maxxis. I get more volume out of a Schwalbe 2.35 than these "2.6" can deliver.
    Dec 2012
    Actually my Butcher 29x2.6 is closer to a 2.5 now about the same as my 29x2.6 Recon.
    Definitely bigger than my 2.35 Nobby Nic. FWIW
    May 2015
    Anyone having problems with these tires. Had both a Butcher and a purgatory (in these sizes) blow the bead off the rim and stretch beyond usability in the process. The purgatory did this while inflating at 25 psi
    May 2015
    No problems, and some blazingly fast DH times. What rims? I'm running the stock front Roval and a Flow in the rear (both 29mm I think).
    WNC Native
    Quote Originally Posted by djbutcher13 View Post
    Myself and couple other buddies have had this issue in the past with some of the other Specialized tires. I had a 2.4 Purgatory do it. If you bought them new, Spec will normally replace them for free in this situation.
    May 2015
    It's on bontrager line pro 30. Was a really nice tight fit. Was fine for like 2 days but then deflated a little so when I went to reinflate it blew at 35 psi. The second Butcher I tried seems to be holding ok. That one blew at a higher pressure so I though maybe it was my fault. But two is a little much. And I've done alot of tubeless setups. Going to contact specialize
  1. Specialized Purgatory/Butcher combo, which up front?
    By Finch Platte in forum Wheels and Tires
    Last Post: 09-21-2016, 03:04 PM
  2. Replies: 6
    Last Post: 12-10-2015, 12:57 PM
  3. Replies: 41
    Last Post: 08-14-2014, 05:36 AM
  4. Replies: 21
    Last Post: 03-29-2012, 08:04 AM
  5. Replies: 4
    Last Post: 12-19-2011, 12:51 PM
Members who have read this thread: 240
