Results 1 to 58 of 58
Thread: McFly 29x2.8
    McFly 29x2.8
    Got mine today. Tough version.
    Mounted on aeffect r 30 mm rim. Tubeless setup was good after messaging bead a bit. Great seal, no air loss. Still threw in 2 oz of stans.
    Size is a bit disappointing. I measured b2b 168 to 170 mm. At 19 psi it measures 64 mm at casing and 68 mm at tread. I rolled it out and it only measures 29.54 inches in diameter. I know tire is designed around 35-40 mm rim, but still disappointed, maybe it will stretch a bit. My bomboloni measures 75 mm on same rim and functions great so my experience has been fine with 30 mm rim and bomboloni was much closer to rated size(2.95)...
    Took out immediately on quick 8 mile ride with decent 1k foot descent. It's a good enough tire, corners better than bomboloni which is why I bought it and gives my yari fork more crown clearance. It might even fit in the rear, it's only 1 mm taller than my goma.
    All in all I would not had bought it if I knew what I know now. I am going to keep dropping psi to test it out, but suspect I will eventually go back to bomboloni or try a dirt wizard (need shorter tires for yari)....I hope th mcfly fits in the rear, will be close.
    Got any photos?
    Sent from my XT1049 using Tapatalk
    Jul 2016
    I got mine mounted up on front as well. went easily on my WTB I35 rim. Mine measure around 69 mm tread. Sure will grow some. I ran mine at 12 PSI, 150lbs, no loss of pressure after rooty hot lap trail. I loved the grip of the tire, ran it hard into some lose corners and hand no problem with bite. Coming from my chronicle 3.O, steering was a lot more responsive and tire still plenty compliant. Think this 29 x 2.8 could be the sweet spot for 29 plus.
    Forgive me if this has been discussed, but where are you guys purchasing this tire?
    Not to savvy. Have pics, but from my iPhone using safari, no option to add to post.
    Ambassador of Chub
    Reputation: Smithhammer's Avatar
    Jul 2015
    2.67" at the tread, on a 30mm rim, for a brand new tire before it's had a chance to stretch, doesn't seem all that "off" to me. It may not ever reach a full 2.8" on a rim that narrow. Check it again after a couple weeks and some riding. Otherwise, it sounds like the McFly is delivering what you wanted?
    "The only way we can truly control the outcome of a ride is not going on it, which is a choice I'm unwilling to make." -K.B.
    WNC Native
    Reputation: nitrousjunky's Avatar
    Either of you guys happen to weight your tire before mounting?
    I got impatient waiting and picked up a Bomboloni, which I'm liking so far. However top clearance is a tad tight on my Loop TR, so McFly just might be the better match for my application (have a 60 TPI DW for winter conditions).
    The numbers i had previously seen on the Bomboloni were 172mm bead to bead, so that isn't a whole lot of difference in volume.
    "I ride to clear my head, my head is clearer when I'm riding SS. Therefore, I choose to ride SS."~ Fullrange Drew
    Quote Originally Posted by Smithhammer View Post
    Yes, I like the McFly tread pattern better than the bomboloni and the tire was more nimble and on rail feeling, but the volume is much much smaller and not sure it is worth the trade off. The McFly got bounced around by rocks, were the bomboloni rolls over. That was initial impression at least. I hope with some more use I like the McFly more...Again, the bomboloni performs great on a 30mm rim at 16 psi (I am 220#) and measures out to 2.9"....
    Quote Originally Posted by nitrousjunky View Post
    I don't own a scale, so no idea on weight. The bomboloni has way way more volume than the McFly. When I crudely measured the b2b on the bomboloni I was measuring in the 180's, but not trying to be precise (ie no interest in arguing about how I measured it, did it just to compare last night)...
    I also ran the bomboloni on a loop tr. I thought it had fine spacing. Better than my Yari. Clearance on yari at crown is 2.5 mm. Now I have at least 6-7 mm. The bomboloni was about 30". I did not do a roll out of it though. I should had before dismounting.
    The tire comparison is with well used Goma 2.4.
    Diameter of Goma on 22 mm rim is 29.38
    Diameter of McFly on 30 mm rim is 29.54
    WNC Native
    Quote Originally Posted by telejefe View Post
    Gotcha, I was going off a previous thread where they ad b2b numbers of all 29+ tires. I didn't take the time to measure mine. I have great side clearance with the i35/Bombo combo in the Loop TR but exactly 3mm clearance to the crown. I'm getting right at 3" on Bombo width with calipers at 15psi too.
    jct
    jct is offline
    Reputation: jct's Avatar
    sell me your mcfly's if you're not satisfied! i want to mount them on some 39mm rims for my SS.
    i will not yield to DH traffic.
    ISO one entry for Grinduro 2017!
    Jul 2016
    Hopefully you just need to get your pressure dialed in. Good luck! Mine was pretty good at first PSI try, probably can drop another 1/2 psi more.
    Jul 2016
    30mm is really narrow for a 2.8" tire. I'm not surprised you're barely getting 2.7" out of it.
    Quote Originally Posted by xblitzkriegx View Post
    I don't disagree and was expecting comments like this. But my bomboloni runs 2.95 on same rim @16 psi for heavy guy. In my opinion 30 mm can work great with bigger tires. I am sure it will be bigger on others, but you can see that on 35 is only 1 mm wider (but prob better volume)....
    I am liking it more and may be a great rear tire for me...oh, just for comparison, my goma is 64 mm at casing on 30 mm and so is the mcfly...so, only point is that it's on the smaller side of the spectrum of 2.8, def not on bigger size. I also suspect some new 2.6s could be as large as this tire....
    On the contrary, call up Stans. They will tell you a Flow MK3 is perfect for a 2.8 and even a 3.0" tire. It's a 29mm internal rim. They advertise them differently, because that's what the market wants to see. One of their reps said Schwalbe believes 38mm is about the max for a 3.0", past that you sacrifice performance. I found this interesting considering they also make the Sentry (32mm), Baron (35mm) and Major (38mm) rims.
    With this info, I'd rather have lighter rim/wheel weight and a proven awesome rim with the FLOW MK3 on a 2.8" or smaller tire.
    Reputation: ARandomBiker's Avatar
    Aug 2014
    Quote Originally Posted by GSJ1973 View Post
    I like Stan's rims but TBH, I think they (and possibly every other rim maker) doesn't know sh!t about plus sized rim/tire width ratios. They say 38mm or less for a 3.0 tire...WTH do they expect you do do with the 52mm Hugo, then? last I checked there were no 29x4.5 tires.
    On the extreme flip side, Jones Bikes, and and a couple other small brands are strongly advocating 2.4's on 40mm rims.
    Edit to add: I've run 29x3.0s extensively on i30 rims, and equally as much time (like months of riding) on i43's. I very much prefer the wider rim. Other's lean the other way. I wouldn't go wider though. I think Stan's went too far with the Hugo.
    I'm not sure if there is truly a "best practice", or if the industry/riders just haven't figured out what it is.
    Back on topic, I've been waiting for this tire to come out. I'm really digging the option of 2.8's especially if there's a proportional weight decrease.
    I'm interested to hear what the early reports say for us Western sandy desert folk. A weight report would be super rad too.
    Donít modify the trail to match your skills, modify your skills to match the trails.
    Jul 2016
    Quote Originally Posted by ARandomBiker View Post
    I think this is exactly it. Also each rim and tire combo vary greatly how they match up, not just plus tires. Each tire manufacture probably designs there tire how they think should match up to rim size. If you look at the Mcfly, its recommended rim width is 35-45.
    Feb 2017
    Now I finally have another option than Nobby Nic 2.6 for my 29r that hungers for max volume but maxes out clearance at 2.8inches.
    Anyone have any input? Trying to decide between these two tire choices for my i29 rim, for which 2.8 is the top end of suggested tire width so they would for sure not measure a full 2.8 even after stretch.
    Reputation: fewg8's Avatar
    Oct 2013
    Anyone know the diameter of these as compared to a fat b nimble?
    Mar 2017
    I'd love to hear any opinions on how this might do as a rear tire with a Chronicle up front.
    I have a Salsa Fargo that will fit a 2.8" in the rear, but any bigger would give me chain rub in the lowest gear. I could convert the rear to boost spacing, but all the parts would cost me several hundred dollars. Not really worth it to gain .2". I've got a trax fatty on back now which is fine, but it's not the most durable tire.
    Jan 2015
    Just got mine mounted up. I think these are going to be a winner.
    The 29x2.8 tough version on WTB Scrapers at 15psi.
    Weights were 972gr and 973gr.
    Knob to knob 2.71" Casing 2.69"
    Easier than the FBNs to setup tubeless.
    Mar 2017
    Quote Originally Posted by Rangie View Post
    Those weights are great news. The Terrene website shows them coming in at a little more than an EXO Chronicle. At around 975g though, that about 75g less than a Chronicle.
    WNC Native
    I do like those weights!
    Student of the Bike
    Reputation: CBaron's Avatar
    How light is an FBN then?
    I know that Rangie's weights are for the 'tough' version, but my Chupas weight a bit less than that at 3.0". I guess I was hoping for even lighter weights...
    My Chupas seem to work well even for the sharp limestone rocks we've got here in my neck of the woods. So I'm after a lighter weight (but not too fragile)tire that I could run in the mtns for my trips were long steady steep climbs are more de' rigueur.
    CJB
    Reputation: bikeny's Avatar
    Quote Originally Posted by CBaron View Post
    CJB
    If you don't want fragile, stay away from the FBN!
    Student of the Bike
    Quote Originally Posted by bikeny View Post
    Yeah, so I've heard. IMHO, its hard to escape physics. So if my Chupas weight 910 and the FBN's weigh XXX, then I'm hoping to target something in the middle. I'd love to find a low-mid 800 gram tire that is 2.8'ish and could be run on my i40 rims.
    I'm quietly holding out for a 2.8-3.0 Maxxis Ikon. I know this is a fantasy tire from my own imagination, but I'd like to have a 2.8 Chupa (29+) too!
    If anyone knows of a tire that fits this description, then feel free to post up. Sorry for the thread jack.
    Later,
    CJB
    Later,
    CJB
    I believe I read that a 29x2.8 Maxxis Ikon is on the horizon.
    Jan 2015
    Fragile is one problem cornering traction is the other. Push too hard in anything remotely loose any find yourself in the dirt.
    Only one ride on the McFly but cornering grip is tons better.
    Ambassador of Chub
    Jul 2015
    Oh please, make it a Rekon instead!
    Jul 2016
    Quote Originally Posted by Rorshanks View Post
    The McFy is more gripper then the Chronicle. Would not think that combo would work good. Now flop your scenario, another story. Just how much gripper, lets say this. I'm running the McFly up front (smaller width tire) with a Chronicle 27.5 3.O in the rear and have no fear of washout! Really digging the McFly after a few rides!
    WNC Native
    telejefe- How does the McFly compare to the Bombo as far as grip goes?
    Since I got the mcfly my trails have been moist from rain so I really couldn't tell much of a difference. Splitting hairs would say mcfly cornered a little better. However, I have the bomboloni back on front and generally like it better. The only clear winner for the mcfly over the bomboloni is the additional clearance at the fork arch. I only have 2 mm with bombo and 6 mm with mcfly....I thought the mcfly would be lighter than bombo but looks like it is the same from other measurements...
    Th mcfly is a decent rear tire and fits at the moment, but expect will will grow in height and be too big soon. Interestingly, not much benefit of the plus in the rear on my full susp. I prefer the goma, just wish the goma wasn't so heavy....might try a nobby nic 2.6 when the Addix become available, or other 2.6s....
    If traction is your driver consider waiting for the terravail kennebec. Terravail sent me initial specs and that tire will be bigger than mcfly and aggressive jobs...I believe they spec there tire on the casing width, not the tread width...I still wish the mcfly casing was a touch more voluminous.
    I am going to mount up the mcfly on Duroc 40's next week, and hope they will support and widen the mcfly to the 2.8 advertisement....
    Oct 2013
    Have you measured overall height and/or circumference?
    Trek Farley 6
    Salsa Bucksaw X01
    GT Grade Alloy X
    Quote Originally Posted by fewg8 View Post
    See post 11. 92.75" circumference, so about 29.55 diameter.
    Oct 2013
    Thank you. The lack of sleep with a newborn must be killing my brain cells. Like this tire but have only 29.75 in the back of the Bucksaw. May have to wait for the teravails
    Trek Farley 6
    Salsa Bucksaw X01
    GT Grade Alloy X
    Jul 2016
    Was able to take Mcfly out on a 20 mile ride today, really pushed the front hard. Mixed between some moist parts of trail, loose rocky sections, crazy NC roots, some dry sandy areas in really fast flowy section, to hitting multiple small jumps in sequence as well. The tire performed flawless, I could not ask for anymore grip. I guess if you ride in mud a lot, then you may need meatier. Tire is very predictable and was just on rails! I had a few hard hits as well, and no burping at all at 12psi.
    My finally verdict is Mcfly flies! Unless durability becomes an issue will be keeping this on for quite a while.
    Jan 2015
    If you can fit a Dunderbeist you can fit a McFly.
    With some time to stretch and few rides the casing now measures 2.75".
    Running at 14/12psi.
    Ambassador of Chub
    Jul 2015
    Initial impressions and measurementals:
    https://fat-bike.com/2017/08/product...-2-8-29-tires/
    Lots more to come....
    Terravails are likely to be bigger. They base their sizing on casing...
    Oct 2013
    Hoping the low profile center tread on the Cumberland gives clearance
    I moved th mcfly onto a 36 mm rim. Casing is almost 68 mm and tread is 70 mm. Still on the small side after 100 miles. I do like it though. Trade offs from bomboloni, but proves proper arch clearance and is much more precision, but not as nice rollover as bomboloni and the cornering really doesn't seam any better. Weight is about same. So it is different and fun and plan to keep rolling for now. Running 16.5 and am 220#.
    Nov 2014
    Mine should be here this week.... I'm less than impressed with Kruger outdoors....
    Jul 2016
    Got a ride on the McFlys. Coming over from 29x3 Chupas. Had been thinking for a while that I wanted go try 29x2.8. First ride was pretty good. Its dry and dusty in the PNW right now. These tires gave me more grip to feel confident to lean the bike over. Noticed a little more rolling resistance over the chupas but that was expected. If these tires can still feel good when the rain comes back the McFly could be my mid summer to early spring tires. Oh yeah, these are mounted up to Duroc 40's. Measured out to about 2.75 the day after mounting.
    Sent from my SM-T900 using Tapatalk
    More Pics
    Here are a few more pics.
    Bomboloni on 30 mm rim (74mm wide tread, 72 casing)
    McFly on 36mm rim (68.5mm wide, 66 casing)
    Goma on 36mm rim (64mm wide, 64 casing)
    All pics show bomboloni, mcfly, goma in order from left to right.
    So, the mcfly is not a 2.8 tire, but it is a decent tire and plan to keep running it. Also disappointed in the wearing. I have less than 100 miles on this tire and falling apart. The Goma is the exact same age and on the rear with no issues. The bomboloni is 500 miles in and looks way better....For $90 a bit disappointed.
    Sep 2016
    Is that on a 29" pike or the 29+ one?
    Quote Originally Posted by Dexter-01 View Post
    27.5+/29" Yari
    WNC Native
    That doesn't look good at all!
    Dec 2013
    Has anyone tried the Light version? How does it stand up to rocks etc?
    Jul 2016
    Interesting that the 29+ version is coming up weird on sizing. I have the 27.5+ version and it's slightly bigger than 2.8" on an i45 rim. The casing still doesn't stick out further than the knobs.
    i45 is prolly max rim width for the tire though as it's starting to get squared off. i40 seems to be the design parameter based on the widths given in this thread in relation to rim width.
    Also, where are you riding that your tire is that chewed up after 100 miles? I have ~65 miles on mine and it's brand new looking. I've used the tire all over the Bentonville, AR area and my local trails, both of which have a good amount of rocky areas (sharp sandstone).
    Ride Everything
    Reputation: GRAVELBIKE's Avatar
    I installed a 29 x 2.8 McFly (tough casing) on a WTB i35 rim and the tire measured 66mm knob/knob. That measurement was taken right after installing the tire, so no stretching or plumping out.
    GRAVELBIKE.COM - ride everything
    jct
    jct is offline
    any one else have some hard miles on this tire with an opinion on wear?
    i'm want to replace my chupas with a knobbier tire for the wet season and the mcfly looks like a good option for my 39mm internal rims.
    Jul 2016
    Quote Originally Posted by jct View Post
    I have about 2 1/2 months on the tire, and no problem with wear on this tire yet. Still loving it and charging hard with it through ever terrain I can find. Still yet to find a situation where does not hold up well traction wise. This weekend was hard charging through damp heavily leaf covered trail and was surprised how well the tire keep me upright.
    jct
    jct is offline
    Quote Originally Posted by SSsteel4life View Post
    thanks! tough casing or light casing?
    Jul 2016
    Tough
    Feb 2006
    I have a brand new set of 29x2.8 Light casing McFlys that I will not be using if anyone is looking to purchase.
    Jul 2016
    It gives up climbing traction compared to the Chunk but it's still plenty grippy. I've also ridden it on the road quite a bit as well, little wear.
    I replaced my 3.0 rear tire with a 29x2.8 McFly. I was looking for better traction in the damp stuff, as well as greater clearance between chain and tire in first gear. This tire is awesome as a rear tire! Traction and mud performance is so much better than my previous WTB Ranger and RR. No more mud getting scraped off of the tire into the drive train. Volume of the tire is on the small side and the tire is not as tall compared to a 3.0, but I only increased my pressure by 1.5lbs to 16lbs, but still experimenting. Tire is very fast as well. This will be my rear tire for now, although I wish it had a tad more volume.
    I like it so much I bought one for the front. I do miss the volume on the front. I would love a 3.0 version of this tire for the front or a Chunk 29x3.0. I don't really have enough time on it to form a true opinion and have yet to ride it in the real rocky and rooty stuff in central PA, but I suspect a minion may be on the horizon. But when it is muddy, these will be my go to tires.
    Tires measured about 2.7. they look more like a large standard 29er tire than a plus tire. Also I will mention again, these tires roll fast, at least compared to the Rocket Ron's and Rangers that I have ridden.
  1. Ardent 29x2.25 lust vs Ikon 3c tr 29x2.35
    By t-ruh in forum Wheels and Tires
    Last Post: 01-24-2014, 08:11 PM
  2. Replies: 13
    Last Post: 12-04-2013, 08:51 AM
  3. 29x2.1 or 29x2.3??
    By maximumsport in forum Wheels and Tires
    Last Post: 08-30-2013, 11:15 AM
  4. Replies: 2
    Last Post: 02-07-2012, 10:41 AM
  5. Geax Saguaro 29x2.2 vs Mountain King 29x2.4 ?
    By Clones123 in forum Wheels and Tires
    Last Post: 05-22-2011, 09:30 PM
Members who have read this thread: 245
