Page 1 of 2 12 LastLast
Results 1 to 100 of 159
Thread: 27.5+ rim list
    Reputation: bikeny's Avatar
    27.5+ rim list
    Someone did this for 29+ rims, thought it was a good idea, so I'll start one for 27.5+ rims as well. I'm thinking anything 40mm outside or bigger should be included. Yes, you can use narrower rims, but they're not ideal. There are probably more that I'm not thinking of, listh them below and I will add to the list.
    Rim Outside width Inside width Weight
    Notubes Hugo 52.3mm 49.9mm 585g
    Velocity Dually 45.0mm 39.0mm 640g
    WTB Scraper I45 49.0mm 45.0mm 650g/687g actual
    WTB Asym I35 39.0mm? 35.0mm 560g
    Nextie 50 50.0mm 45.0mm 490g
    Nextie 40 40.0mm 35.0mm 410g/440g/500g
    Ligthbike 50 50.0mm 45.0mm 450g
    Lightbike 38 38.0mm 31.6mm 440g
    Derby 40.0mm 34.0mm 445g/465g/485g
    Additions on 4/16/15:
    IBIS 741 41.0mm 35.0mm 473g
    Fatlab Plus55 55.0mm ? 642g
    Loaded Precision 40.0mm 35.0mm 420g
    Sun Ringle Mulefut 50.0mm 45.0mm 615g
    Carbonbicycle 40.0mm 35.0mm XC:400g AM:450g DH:520g
    Update 8/19/16: Just realized I haven't updated this in a while, and there are lots of new rims out there.
    DT Swiss XM 551 44mm ? 595G
    Easton Arc+ 35 39mm 35mm 540g
    Easton Arc+ 40 44mm 40mm 595g
    Easton Arc+ 45 49mm 45mm 650g
    Halo Vapour 50 50mm ? 700g
    Kore Realm P35 42mm 35mm 575g
    Kore Realm P45 52mm 45mm 645g
    Spank Oozy Trail395 39.5mm ? 540g
    SunRingle Duroc 40 40mm 36mm 515g
    SunRingle Duroc 50 50mm 46mm 610g
    Wisky Parts Co. #9 50mm ? ?
    WTB Scraper I40 44.6mm 40mm 555g
    Reputation: phattruth's Avatar
    Ibis 741 41.0mm 35.0mm 473g
    The Truth will set you free.
    ....but it might offend you first!
    Reputation: Stopbreakindown's Avatar
    On the WTBs website Scraper info claimed weight is 560, it might be a typo. It's listed at 650g on most retail websites.
    Thanks for the list!
    Reputation: MMcG's Avatar
    Jul 2003
    FatLab FatBike-Plus55 Disc Rim
    Universal Cycles -- FatLab FatBike-Plus55 Disc Rim
    • Weight: 642g
    Rocks belong
    Quote Originally Posted by Stopbreakindown View Post
    687g here
    I'd add the Velocity Blunt35 for frames that have limited rear tire clearance. I'd also add the recently announced WTB Asym i29 & i35 rims... Availability this June for the new WTB Asym rims.
    I like 'em long, low, slack and playful
    Chris Bling
    Reputation: dustyduke22's Avatar
    Lets add the Loaded Precision X-40
    40mm external, 35mm internal, no weight advertised. Probably mid 400's
    Loaded USA :: Loaded Precision Components :: Products
    The obsession of wheels fused with the passion of cycling
    Affordable Custom Wheels
    Doesntplaywellwithmorons!
    Reputation: DeeEight's Avatar
    This is the technical info for the 650B scraper rims WTB supplies to dealers, note the weight is 650 grams.
    "Item Specifications
    Color Black
    Weight 650
    Width 49
    Material Alloy
    Hub Drilling 32
    Rim Depth 17.88
    Brake Compatibility Disc Only
    Manufacturer Spec ERD 565
    Valve Presta
    ISO Diameter 584 / 650b / 27.5"
    Valve Length Short
    Wheel Size 27.5"
    Tire Type Clincher
    Tire Type Tubeless Compatible
    Rim Center Offset 0
    Rim Joint Welded
    Brake Track N/A
    Defined Color Black
    Internal Rim Width 45Item Specifications
    I don't post to generate business for myself or make like I'm better than sliced bread
    Also Woven Precision in Canada will have mid-fat 650B carbon rims in a few months, as well as Boost 110/148 hubs sooner than that. As soon as their first samples arrive I'll try and get some pictures/measurements. They already do 35mm (external) 650B and 85mm 26er double-wall carbon rims which are easily taped and run tubeless.
    50mm outer width / 45mm inner width
    615g
    Been looking into 27.5+ for my yelli. Can someone please suggest the most bang for your buck setup? I'm 230lbs and the bike has a 120 mm manitou tower pro.
    Chris Bling
    Quote Originally Posted by thunderzy View Post
    For rims, I would go with Velocity Blunt 35's. You won't get near the volume of a full on B+ rim, but you will still get much of the benefit of the higher volume tire. For Hubs, you can't beat Hopes for the price. There are cheaper options, but they probably don't have the reliability factor as Hopes...
    If you are interested, I have a brand new set of black Velocity Dually rims collecting dust in my shop that I need to move...
    Quote Originally Posted by dustyduke22 View Post
    Under "tech" specs it lists the rim at 420g (+/- 15g).
    @2whlfun
    I'm using a set of American Classic Wide Lightning 27.5 wheels 29.3mm internal. Until my Nextie rims arrive. They work well even though they are considered narrow for this new category of tires.
    Carbonbicycle 40/35 400g XC 450g AM 520g DH
    Name:  27.5 profile.png
    Dec 2012
    good to see there will hopefully be some affordable rims (i.e. comfortably <$100) coming too. These off the proposed Mongoose Ruddy
    Oct 2013
    Alex MD50 - 55mm external 50mm internal
    Baby Bear is in the house
    Reputation: r1Gel's Avatar
    I don't know if there's a rim only option, but the Roval 650b+ of the 2016 Specialized Fuse and Ruze Pro is 38mm (inner width I suppose)
    Dec 2012
    Quote Originally Posted by skylerd View Post
    You sure they are doing them in 27.5? Only listed in 29" and 24" here? I would like that to be true through!
    Alexrims - cycling wheels
    Live Free & Ride
    Reputation: NH Mtbiker's Avatar
    Quote Originally Posted by lukeNZ View Post
    Yes, found em under Fat bike here:
    17 Moto Ti cross
    14 GT Zaskar 9r
    15 Moto Night Train
    08 BMC Trailfox
    08 Bad Boy Ultra
    06 Cannondale Rush
    99 GT XCR
    Mar 2014
    Absolutely same 40mm width rims as CarbonBicycle. CarbonSpeed seems to offer better price, and they get wider 42mm/36mm rims, even 50mm width 27.5+ rims
    Xiamen Carbon Speed Sport Goods Co.,Ltd
    Mar 2014
    I got new quotes from Peter on their RM750C 27.5+ and RM950C 29+ rims, only 180 USD/piece. Is it too cheap ?
    Live Free & Ride
    Has anyone tried or built up the Mulefut 50 SL? At $122 and a little over 600 grams seems to be a great value to me. I know the 80 SL has received decent reviews, but have not heard much around here on the 27.5 - 50 SL. Please report if you have or know of reviews on this particular rim. Thnx!
    17 Moto Ti cross
    14 GT Zaskar 9r
    15 Moto Night Train
    08 BMC Trailfox
    08 Bad Boy Ultra
    06 Cannondale Rush
    99 GT XCR
    Live Free & Ride
    Quote Originally Posted by Bikrider View Post
    Will keep ya posted as I just ordered a set of the RM750C's. Having them laced to 150 front and 197 rear hubs for the fatty! Still deciding on a few different tires for these.
    17 Moto Ti cross
    14 GT Zaskar 9r
    15 Moto Night Train
    08 BMC Trailfox
    08 Bad Boy Ultra
    06 Cannondale Rush
    99 GT XCR
    Mar 2014
    Quote Originally Posted by NH Mtbiker View Post
    Got your rims ? Looking forward to your pictures
    Live Free & Ride
    I did get them today actually....and already dropped them off at my lbs for lacing! I shot some pics and weighed them right out of the box too. Will post up later today...
    17 Moto Ti cross
    14 GT Zaskar 9r
    15 Moto Night Train
    08 BMC Trailfox
    08 Bad Boy Ultra
    06 Cannondale Rush
    99 GT XCR
    Live Free & Ride
    Take a look here:
    http://forums.mtbr.com/27-5-29/b-setup-moto-981375.html
    17 Moto Ti cross
    14 GT Zaskar 9r
    15 Moto Night Train
    08 BMC Trailfox
    08 Bad Boy Ultra
    06 Cannondale Rush
    99 GT XCR
    Syncros TR1.5 Plus
    Alloy i40
    28h
    Weight ???
    Sep 2015
    Quote Originally Posted by r1Gel View Post
    There isn't a rim-only option, and it doesn't look like they are selling the 38mm alloy wheelsets yet, but they are selling carbon 38 mm ID Roval wheelsets, at least with the BOOST hubs. It's a nice looking wheelset, assuming the 24/28 spoke counts work for you. I don't see a non-BOOST option at the moment.
    Sir Shreds-A-Lot
    Reputation: trekninja's Avatar
    Oct 2007
    Syncros TR1.5 Plus
    Alloy i40
    28h
    Weight ???
    that a nice looking wheel, wish it came in a rim only option
    1985 Trek 670
    2016 Kona Process 111
    2017 Ritchey P29er
    2018 Trek Domane SL6
    DT Swiss XM551
    28/32h
    i40
    ERD 564
    Weight: 595g
    DT Swiss - XM 551
    Found this at the bottom of the link:
    Only applicable with DT ProLock nipples. ERD and weight indication include PHR washers.
    Rocks belong
    DT Swiss XM551
    28/32h
    i40
    ERD 564
    Weight: 595g
    DT Swiss - XM 551
    Wow. That'll give the WTB Asym i35 and Velocity Dually a run for their money. Especially if the claimed weight is accurate.
    Yeah, retail on a couple of the .de sites have them retailing for $97ish
    Pretty good value for weight and tubeless compatibility. I don't have any experience w/ dt swiss rims. Any good?
    Jan 2015
    Fatlab 27.5 x 55
    Stupid me thought I bought tires as well!!
    I'll reconcile that and get out there
    Weighed the rear 1260 grams,
    Jan 2015
    Oh, and dt Swiss, you can see them in the background above, are quite nice
    Those are 26 inch. Setup tubeless well and hold nicely. A fine rim if I do say so
    DT Swiss XM551
    28/32h
    i40
    ERD 564
    Weight: 595g
    DT Swiss - XM 551
    Are these available yet? I can't find them on the google machine. Curious about real world weights.
    Feb 2012
    Quote Originally Posted by Slow Danger View Post
    At least from Germany you can get them.
    DT Swiss XM 551 black 650b (only possible with black or red DT Pro Lock Nipples) | Kaufen | Laufräder für Fahrrad und Bike - Onlineshop Action Sports
    https://www.bike-components.de/de/DT...l-2016-p45268/
    No clue about the real world weight but seriously considering those rims.
    Reputation: Atomik Carbon's Avatar
    Out Atomik Carbon Chubby and Phatty rims are now available.......First shipment of phattys were presold, second shipment will be here in about 1 week.
    atomikcarbon.com | High Performance Carbon Fiber Mountain Bike Components
    Sep 2013
    Hi all,
    I like to contribute another 2 rims,
    NOX Kitsuma(AM) 42mm external, 36mm internal, 460grams
    Zelvy 27.5 41mm external, 35mm internal, 460 grams
    Anyone have any experiences on these for plus setup?
    Thanks.
    Jun 2012
    Easton's ARC Plus rims are now listed on their website with 35, 40 and 45 internal widths.
    ARC PLUS - Easton Cycling
    Jun 2012
    Also have the Kore Relm rims been discussed yet?
    https://www.universalcycles.com/shop...?category=5987
    They seem to be lighter and cheaper than the WTB or Easton offerings. Wonder how durable they are?
    My Kore Relm 30 hoops should be here today. Plan is to build a cheap set of 27+ wheels for my El Mar. Went with Koozer hubs. If I like the plus size I'll build some nice light wheels later. Will update as I build them.
    nvphatty
    Guest
    Quote Originally Posted by StumpyandhisBike View Post
    still don't see them in stock any place.
    Rippin da fAt
    Kore Realm P45 27.5" Disc Rim $62.00 on universalcycles.com. more like it for a 3.oh yeah! 645g per the website. 52/45mm
    Still waiting on the return of my Scrapers from the anodizer. gotta get rid of the hearse black so they can be seen in the middle of a pair of NN 3.0's.
    Get fAt, Stay fAt, Ride fAt
    Doctor recommended...
    nvphatty
    Guest
    Quote Originally Posted by BansheeRune View Post
    a costly process but the end result should be sweet.
    Ryde has got 2 midfat options.
    35 mm inner width 590gr
    42 mm inner width 640gr
    Looks like solid rims with extra support/beams inside the construction.
    http://www.ryde.nl/rims
    Sent fra min D6603 via Tapatalk
    Oct 2015
    Zelvy do 50mm (45mm internal) and a 40mm (35mm internal) carbon rims, excellent quality and great warranty.
    Spank are also releasing a 39.5mm Oozy alloy (unsure of internal but should be about 35mm), it's listed on CRC buy not available yet and the info is for a different size. Spanks website is way behind.
    nvphatty
    Guest
    Quote Originally Posted by GRPABT1 View Post
    yea no doubt! behind in website, behind in email communication etc.
    Brown Jersey Winner
    Reputation: Mumonkan's Avatar
    Jun 2015
    i picked up a pair of DT Swiss XM 551 yesterday, they are very light and very clean, and they do indeed come with the nips and washers
    i havent weighed them on a digital scale but on my bathroom scale, compared to a pair of unlaced wtb scrapers they are roughly a pound lighter
    very excited to get them built, theyre definitely a high quality rim. they were $110/ea for me but i got the bro discount @ LBS. in the states it looks like theyre going for $125-140 retail
    I'll be the axe that clears the forest.
    https://dirthurt.wordpress.com/
    Got my xm551 today, and just laced them all up. Hope Pro 4 boost, DB Alpina spokes 2.0-1.7-2.0), alu spokes an washers that came with the rims. Total 2130gr. A bit more than I was hoping for, but still descent. Each rim were about 25gr heavier than official numbers.
    Nov 2015
    Idea!
    Nextie 40/33
    Pardon the crap fotos
    This being my 2nd B+ wheelset, wanted to try smthg lighter w/o robbing a bank. Dually 43/39 i had weighed 640g
    Brown Jersey Winner
    Jun 2015
    so i got the XM551's built up
    -super light
    -super well made
    -no visible seam
    -round, no flat spots
    -tubeless perfection: trail boss 3.0 mounted up and held air with zero sealant, snapped into place at around 40psi
    -build up super easy, by counting turns and doing everything evenly, i didnt have to true either wheel at all
    all in all these are probably the most pain free rim ive ever built a wheel with
    bonus points: trail boss 3.0 on this rim measure out to 71.8mm/2.8" freshly mounted. after some riding they might relax and stretch out to 3" but we'll see. tires are FAST though and have a lot of bite in the corners
    nvphatty
    Guest
    Very nice summer semi-fat setup.
    Rippin da fAt
    Atomlab joins the B+ fray, film at Atomlab » SL 27Plus Rims
    nvphatty
    Guest
    Atomlab joins the B+ fray.
    dang it 35i
    Rippin da fAt
    Quote Originally Posted by nvphatty View Post
    dang it 35i
    hehe!!
    nvphatty
    Guest
    I'm still undecided between the arc 30 & 35 for 2.8 fitment... the arc 35 is very scarce right now and has been for awhile and from what i gathered it won't be avail till mid may at a favorable price, hence why not the arc 30??
    nvphatty
    Guest
    spank oozy trail 395+
    Rippin da fAt
    0.o
    Found this...Way too narrow for Sarge's 3.oh's...
    https://www.thegravitycartel.com/pro...-bite-wheelset
    nvphatty
    Guest
    0.o
    There newest rim oozy trail 395+ is i35mm internal and via my email exchange with them today they are avail but not listed on their site as of yet.
    Last edited by nvphatty; 08-19-2016 at 08:13 AM. Reason: edited for updated sizing.
    Rippin da fAt
    Fair enough...
    Sent a pair of Scrapers out for anodizing cause the black just doesn't work for me. Gotta have enough rim for the 3.0's to be 3.0's without max PSI to prevent foldover in the corners. Oh, and so I can get trialsy with em too.
    nvphatty
    Guest
    get giggy (i mean trailsy)
    Rippin da fAt
    It doesn't always require this...
    nvphatty
    Guest
    Their newest rim oozy trail 395+ is 35i and via my email exchange with them today they are avail but not listed on their site as of yet.
    edited my previous post to correct rim width.
    Just received a pr of them this AM. Lazer etched rim logos, nice rim strip and 580g each. I will eventually have them powder coated white and have custom decals made.
    Formerly PaintPeelinPbody
    Reputation: PHeller's Avatar
    Dec 2012
    A quick look around gives me these numbers for 275 alloy 35mm internal options:
    WTB i35 Asym: 610g actual
    Spank 395+: 580g actual
    Easton Arc 35: 540g claimed
    Kore Realm P35: 575g claimed
    DT Swiss XM551: 595g claimed 620g actual.
    GIS/GPS Pro using ArcFM for Utility Mapping - Always willing to connect with other MTBers in the industry.
    nvphatty
    Guest
    I managed to go through with this process after some research and Q&A with spank and other hoop manuf with respect to powder coating / curing temp of 400d with these rims since they are sleeved with an epoxy resin, hence my concern, however everything went well with a pre bake for 1 rim to assess what may or may not result in failure. The result was positive and the PC shop went ahead with both.
    Quote Originally Posted by PHeller View Post
    Dec 2010
    52mm wide Carbon rims from Hulksports,130.00 per rim.
  67. #67
    Rippin da fAt
    Finally a carbon rim without being fleeced!?!? @.@
  68. #68
    Reputation: Epic_Dude's Avatar
    May 2010
    Chinese carbon rims are quite common at that price. Lots of choices out there, I prefer to deal with Peter at xmcarbonspeed.com instead of AliExpress.
  69. #69
    Rippin da fAt
    I've seen loads of em over 200.
    Epic, your avatar looks like my fata$$ cat.
    Fat and fat...
  70. #70
    Reputation: noosa2's Avatar
    Quote Originally Posted by techfersure View Post
    Where do you get these for 130 per rim?
  71. #71
    Dec 2010
    Quote Originally Posted by noosa2 View Post
    Ebay,28 spoke front 32 rear.
  72. #72
    Rider/Builder/Hacker
    Nov 2015
    Quote Originally Posted by Mumonkan View Post
    -super light
    -super well made
    -no visible seam
    Looks burly!
    What did the ERD measure?
  73. #73
    Reputation: andrepsz's Avatar
    Jan 2013
    Quick question: is 35mm Outer rim OK with 27.5 x 2.8 tire? Anyone using this config?
  74. #74
    Dec 2012
    It's fine. I run a 275x2.6 on old narrow Stan's Flow and never have any issues.
    The only downside to a 35mm rim is running something like a 2.25 tire where at lower pressure you might risk denting the rim.
    That being said, I plan to run 35mm internal rims with 2.3 tires. Not worried.
  75. #75
    Jan 2013
    27.5+ rim list
    That's good info, I'd be curious to know on 2.8's. I plan to have that as front wheel 27.5 rim with 35mm outer to fit 2.8 tires to play and 2.4 tires in case I want to race ( 2 or 3 times as year).
    I guess I'm good then...
  76. #76
    That bike looks sweet! That's what I call a real Plus bike, 52mm rims and 3.25" tires. None of those wimpy 2.8" tires and 30mm rims!
  77. #77
    Where are you seeing that price? When I go to their website, I see $228, about the same as all the other Chinese carbon offerings.
  78. #78
    nvphatty
    Guest
    Quote Originally Posted by andrepsz View Post
    yessir yer golden, well sort of..
  79. #79
    Reputation: Bullit_cn's Avatar
    Read somewhere that 40mm ID is the ideal size for 2.8 to 3.0 tires?
    Can anyone confirm this?
    When trails gets tougher, Just stand up and deliver.
  80. #80
    Dec 2010
    Quote Originally Posted by Bullit_cn View Post
    Good choice,Have 52mm on mine,ride aggressive and with thin sidewalls less chance of tire running over rim and or burbing.
  81. #81
    I am not sure though that is why I'm asking. I was about to order a LB 50mm rim with 45ID and from the comments I saw, people are asking for 40mm ID...
  82. #82
    nvphatty
    Guest
    i40-45 and 3.0 setup is just right.
  83. #83
    Thanks Nvphatty.
    It seems I am back to hunt a rim with 40ID then. Any suggestions?
  84. #84
    Rippin da fAt
    WTB is offering the i40's soon if not already offering em.
  85. #85
    Something I saw on the spec sheet for the new Jet 9 RDO:
    Wheels: STAN'S NOTUBES NEO/ZTR BARON S1, 110X15MM FRONT, 148 X 12MM REAR
    What are these new Stan's Baron rims and what are their dimensions?
  86. #86
    nvphatty
    Guest
    Thanks Nvphatty.
    Easton arc 40 is 1 such animal.
    https://www.coloradocyclist.com/east...ncher-rim-27-5
  87. #87
    Dec 2010
    Liking tire combo,Dirt Wizard rear and Dura Crux front. Hulksports 52mm rims holding up real well and have not been gentle on them,for the money hell of a rim.
  88. #88
    MTB B'dos
    Reputation: LyNx's Avatar
    For me, my next "fat" rim will be one of these from KORE. Much cheaper than either the WTB or Easton offerings (nearly 2 of these for 1 Easton and definitely 2 for price of 1 Scraper), great if weight doesn't matter too much to you and $$ savings do,plus I like riveted eyelets.
    https://www.universalcycles.com/shop...&category=5987
    Thanks Nvphatty.
  89. #89
    In dog years, I'm dead.
    Reputation: burtronix's Avatar
    Quote Originally Posted by tri-tele View Post
    Wheels:STAN'S NOTUBES NEO/ZTR BARON S1, 110X15MM FRONT, 148 X 12MM REAR
    Might be a typo. Stan's carbon wheels are called Bravo.
    Whatever your hand finds to do, do it with all your might.... (Ecclesiastes 9:10)
  90. #90
    I made a phone call today.
    NOT a typo, keep you eyes open for info on Barons in the next few weeks.
  91. #91
    Nov 2015
    @nvphatty and other that have experience with the Spank Oozy Trail395+...
    I've just received mine, and measured the ERD at 557mm. Does this match what others are measuring? Hoping to start my first wheel build off with good numbers.
    Thanks,
    c275
  92. #92
    nvphatty
    Guest
    Quote Originally Posted by carbine_275 View Post
    Thanks,
    c275
    yessir it is.
  93. #93
    Rippin da fAt
    From Spank's website...
    ERD (mm++):554 (27.5") / 591 (29")
  94. #94
    Nov 2015
    yessir it is.
    Thanks for the confirmation.
    I measured both rims in 3 places.
    First rim was 557 in all 3 places.
    Second rim measured 556.5/557.5/557 for a 557 avg ERD
    Any recommendations for a reasonably priced truing stand?
  95. #95
    nvphatty
    Guest
    park is certainly one to consider.
    Professional Wheel Truing Stand | Park Tool
  96. #96
    Land of the 230+
    Reputation: GuitsBoy's Avatar
    Sep 2013
    Do you plan on building a bunch of wheels in the future? If not, just flip your bike upside down and use the frame and fork as a truing stand. Use a ruler or simply your finger as an indicator. Zero bling factor, but it sure is cheap.
  97. #97
    Land of the 230+
    Sep 2013
    Mine weighed in at 705 and 711 grams, so a good bit over claimed weight. UC regularly has 10% off 100 coupons floating around, so I got my pair for $119 after shipping fees (they didn't qualify for free shipping).
    But so far they seem like decent rims.
  98. #98
    nvphatty
    Guest
    Quote Originally Posted by GuitsBoy View Post
    a ziptie placed on the fork tube works well.
  99. #99
    Land of the 230+
    Sep 2013
    My only issue with that is once its cut, there's no way to make it longer. My go-to has been a wooden ruler, and a small bar clamp with rubber pads.
    I've also used a grease pencil back in the bmx days, that way you can physically see which spokes need adjusting.
  100. #100
    Just added a bunch or rims to the list. Check out the first post.
  1. My list of HT 29 which one
    By cloudbuster in forum 29er Bikes
    Last Post: 06-27-2013, 05:43 AM
  2. Where is that list?!
    By junyr73 in forum General Discussion
    Last Post: 05-01-2013, 01:58 PM
  3. what used mtb from this list
    By bob7 in forum Bike and Frame discussion
    Last Post: 04-26-2012, 07:22 AM
  4. What's on your XC list
    By no nancies in forum Washington
    Last Post: 09-29-2011, 07:40 PM
  5. FR 180 Wish list
    By toHELLuRIDE in forum Ellsworth
    Last Post: 05-02-2011, 06:01 PM
Members who have read this thread: 58
